CK20 HST Starting Problem Fixed
   / CK20 HST Starting Problem Fixed #1
39President
I'll start with the problem. Turned on ignition switch. NO dash lights, turn key to start, nothing, just like battery missing. Turned switch on & off multi times, dash lights came on along with Glo Plug light. As soon as I tired to start, dash lights went off & would not crank. Turned switch on again, this time motor cranked but would not start, just cranked & cranked. Tried again and motor started as always in about 5 seconds. Battery connections were fine. Unpluged every connector under hood. Pluged & unpluged every connector multi times then put dielectric grease in every plug. Careful unpluging connectors so you dont break clips holding connector togeather. I then sprayed electrical cleaner into ignition switch. Turned key on, dash lighs & Glo Plug light came on, motor started in it's usual 5 seconds and is now fine. Machine is stored in unheated portable garage and has been in the rain once last summer. I have found that electrical connectors don't have to be corroded to not make good contact, just a little film of dust & crud can give intermitent contact. This formum has helped me many times, hope this helps someone save $$$ and headaches!
   / CK20 HST Starting Problem Fixed #2
Thanks for sharing.
I had something similar to that happen to me on an ATV once just as it was getting dark and I was out on the woods with no landmarks....
Jon
Sounds like it was an exciting night Jon! I forgot to mention I also repeatedly unpluged & pluged all the fuses in the fuse panel & then put dielectric grease in the holder slots.
Nick
   / CK20 HST Starting Problem Fixed #4
Glad you shared your solution. I would have bet that it was a dirty or loose ground on the battery. (I would have lost).
Hey, I see you name is Nick but what's with the 39President handle?
Jimmy Carter fan?
   / CK20 HST Starting Problem Fixed #5
Gotta say I was betting on loose or corroded ground also. Live and learn!
I'm restoring a 1939 Studebaker President.
Nick
   / CK20 HST Starting Problem Fixed #7
I had problems starting mine as well, mine would either do nothing or it would crank and start, but as soon as I let off the key switch it would shut off.
My dealer replaced the switch with a new one. It has a new part #. My dealer told me that Kioti has had problem with it and changed the switch to resolve the problem.
Mine has been fine since.
Ken
Good info Ken. When I first started to check the problem, I noticed the tumbler in the ignition switch seemed pretty sloppy, maybe spraying the electronic cleaner helped. There are to many plugs & fuse holders to clean & check 1 by 1 to have pin pointed the bad connection. If this happens again, I'll try to bypass the ing switch & see if that works.
   / CK20 HST Starting Problem Fixed #9
Nick
Shamefacedly I hadn't considered that. I should have guessed as my brother is an affectionado and currently has a 56 Skyhawk (rare) a 62 GT, a 51 Starlight Commander, a 63 Avanti, a 66? Lark and maybe another one or two.
He owned a few Silver & Golden Hawks (supercharged) over the years as well as a station wagon. Member of the Stude club for probably 40+ years too. Matter of fact, his AOL handle is skyhawk01ny. Nice to see there are still some folks around that appreciate them. Post a picture sometime and remember to record the stages of the restoration for posterity ;).
Be darned if I can figure out how to post a photo. Clicked on icon to insert photo & nothing happens!
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR1BJ325796 (A51572)
2011 International...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
New Holland 451 Sickle Bar Mower (A50515)
New Holland 451...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A52748)
DeeZee Crossover...
2012 Infiniti G25 Sedan (A50324)
2012 Infiniti G25...
