Snow CK20 getting stuck in snow
   / CK20 getting stuck in snow #1
kioti180
Wakefield, NH
2004 Kioti CK20
My 04 ck 20 gear can not seem to get out of its on way in the snow. The front wheels do not seem to be working while in four wheel drive. I raised up the front end, throttle up and back tires spinning fast but the front tires are barely moving. I can stop them with my hand and spin them the opposite direction. The four wheel drive appears to engage and disengage.
I always have it in four wheel drive when using it and this summer I may have been a little hard on it doing work on our dirt road. but know with a lot of snow on the ground, the tractor is getting stuck on flat ground. When it use to go right threw it, even up my driveway.
   / CK20 getting stuck in snow #2
By the sounds of it, your FWD is not engaged. Check for a broken or bent lever that shifts the front wheels in and out.
Steve
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A52128)
Texas Post Driver...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
2019 Kenworth T880 T/A Wet Kit Day Cab Truck Tractor (A50323)
2019 Kenworth T880...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A52128)
2021 John Deere...
