</font><font color="blue" class="small">( so the PTO stops when you depress the clutch, and if you don't depress the clutch, the PTO momentum can push the tractor if it's in gear. John )</font>
John-
Yeah, thanks for the heads-up and for being conscientious. Several weeks ago I read a similar post you made on this subject, and have since chatted with neighbors about their older tractors that have this same issue with a transmisssion PTO. Both say it's manageable, but we all agree that for someone who doesn't have tractoring experience or knowledge of the issue, it could be quite surprising/dangerous the first time it happens.
Some other thoughts on this:
• With due respect I may be able to elaborate on your quote: Even if you *do* press the clutch while in gear, the implement's momentum can push the tractor via the transmission.
• One neighbor uses an 'overspin' or 'over-run' clutch on an old Ford 8N between the rear PTO output and the implement shaft. This allows the flywheel of his brush cutter to spin freely once the PTO is disengaged, without pushing the tractor. If I get a CK20 gear I can try it out.
Thanks again, and I'm sure to have plenty more questions. I'm impressed with Kioti, and this forum has been good to break through some of the crap/misinformation that gets thrown around when you find yourself talking to dealers of equipment that has much more 'brand name recognition'. My wife and I had to laugh when she was browsing Kubota BX models at the county fair the other day. When she told the dealer we were cosidering a Kioti she was told: "Run away from Kioti. Those Chinese tractors aren't worth...blah,blah" So anecdote aside, good work to all who come here to give good information.
Tyler
(note: I've requested that my Display Name be changed to just Tyler - may be different by next week)
