ck20 forward/reverse speed
   / ck20 forward/reverse speed #1
jon dirt
Burrillville RI
Kioti CK20
My hydraulic pump went bad a few months ago. The dealer replaced it, now it seams to go faster travels in reverse than forward. Is it passable that he swapped ports or is there a flow control that need to be adjusted?
   / ck20 forward/reverse speed #2
I'm assuming your's is a HST tractor. I don't have a 20, but my 25 (and I think all of the HSTs) is set up so the the hydraulic pump is allowed to have more stroke (which means more speed) in the forward direction. You can look at the decal on the tractor or the owners manual to confirm this. I haven't had my pump out so I don't know if it is possible to reverse the forward and reverse ports when installing it or to set the forward stroke to what is the reverse stroke setting, but it sure sounds like that is what happened when they reinstalled your pump.
2006 Freightliner Business Class M2 Beverage Truck (A47384)
2006 Freightliner...
Frontier FM2015 (A50120)
Frontier FM2015...
2012 Ford F250 Pick Up (A47384)
2012 Ford F250...
2014 Landoll VT-Plus (A52349)
2014 Landoll...
1999 Ford F450 Dump / Plow Truck (A50514)
1999 Ford F450...
2016 Ford Transit 350 Cargo Van (A50323)
2016 Ford Transit...
