CK20 blowing blue smoke??!!?
   / CK20 blowing blue smoke??!!? #1
EGo_SmAsH
Bronze Member
Canada
JOHN DEERES
Was chipping some branches today with my CK20 HST (750 hrs) and noticed alot of blueish smoke from the exhaust. I was running it at 540 rpm but there was not a heavy load on the motor. I shut it down and checked the oil-it was fine so I continued chipping until i was done. When I got back to the garage I changed the engine oil and filter, cleaned the air filter and dumped 1/3 can of Seafoam in the tank.
Do I have a fuel issue here?? If I have a dirty injector will the Seafoam clear it up....or do i have bigger issues? I have aloso noticed a minor loss in power for the last couple months...not sure if it is connected with this or not. Thanks
   / CK20 blowing blue smoke??!!? #2
Loss of power is your biggest clue. Seafoam is great, but if a cylinder has a problem, as an example, chances are nothing will change. I would not use the tractor further until you determine the cause and solution. If the problem is as simple as a clogged or non- functioning injector the Seafoam might change the symptoms, but I think it is unlikely. It would be a good idea to verify each cylinder's injector function and if they are good you may have to dig deeper to see if you have a gasket or head/valve/ or ring problem.
Is this machine under warranty? If so contact your dealer right away- and even if it isn't contact them for their thoughts on where to look if you are going to do the diagnosis.
   / CK20 blowing blue smoke??!!? #3
Sounds like a leaky injector allowing some oil into the cylinder...
It's normal for a little while the engine is cold but if you see blue smoke when it's warm and under load then start looking for oil consumption.
The warranty ran out 3 months ago. I put over an hour on it today cutting grass and it ran fine with no smoke except for on start-up for about 15 seconds. Hopefully the seafoam will cure this!!
   / CK20 blowing blue smoke??!!? #5
15 seconds! I never get any blue smoke at all on my 1000 hour CK30. No white smoke either. Only the blackish grey puffs of unburnt fuel at startup or when applying a sudden load.
I would say that blue smoke is never normal.
   / CK20 blowing blue smoke??!!? #6
I'm using my SIL's CK20 and notice a few seconds of blue smoke from the exhaust on start. It runs great and I have been using sea foam.. It only does it on start. Anything I should worry about? Have no diesel experience..
   / CK20 blowing blue smoke??!!? #7
A little smoke at start-up no matter the color is normal. There are so many variables that can lead to a little oil or coolant getting in the cylinders that it really isn't a problem unless it does it after the engine is warm and under load.
If it only does it on start-up then no I wouldn't worry about it.
   / CK20 blowing blue smoke??!!? #8
Blue smoke = oil in cylinder, black smoke = unburnt fuel, white smoke = antifreeze/water in cylinder. I'm with everyone else have it checked ASAP, it would be a good idea to do a compression check, that will tell if you have a ring or valve seal problem.
   / CK20 blowing blue smoke??!!? #9
WHAT????? there is not a situation where a little coolant getting into a combustion chamber is ok... !
Coolant should NEVER be in the combustion chanber.
As others have stated, blue smoke is generally oil being burnt.... an exception to that could be a PC engine with a nozzle issue, sometimes it will show up as a blueish looking smoke...
Not sure about the Kiotis, are they PC or DI engines???
   / CK20 blowing blue smoke??!!? #10
For the most part, yes, that's what happens to Diesels, but you can also
get white smoke from completely unburnt fuel, as when starting an
engine that does not fire.
IMO, any blue smoke is bad, but only at start-up points to leaky valve
guides, which do not need to be fixed for possibly many years. You can test
this theory by operating the tractor under engine-braking (hi-vacuum).
You can see if the rings are tired by pulliing off the PCV hose and seeing
if you have excessive blow-by gases coming out of it.
Of course, a compression test is a good thing, but hard to do because
you need an injector adapter or glow plug adapter. (CK20 has glows, and
is a non-DI engine.) Injectors are often hard to remove, too.
The best scenario for the OP is a leaky head gasket, which gives him low
compression in one cyl and an oil leak into the cyl.
Flatbed Equipment Trailer (A50515)
Flatbed Equipment...
SET OF HANG-ON PALLET FORKS (A51243)
SET OF HANG-ON...
2020 CATERPILLAR 315FL CR EXCAVATOR (A51242)
2020 CATERPILLAR...
2007 Ford Edge SEL SUV (A50324)
2007 Ford Edge SEL...
2013 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,400LB 3 Ton Crane Service Truck (A50323)
2013 Ford F-550...
UNUSED FUTURE QUICK ATTACH 72" CURVED LOG GRABBER (A51244)
UNUSED FUTURE...
