CK 3510 "Linked Pedal Kit"..... Anyone?
   / CK 3510 "Linked Pedal Kit"..... Anyone? #1
Hdoilcan
USA
2018 KIOTI CK3510SE CAB, 2475L BACKHOE, 72 BOX BLADE, 72 REAR BLADE, 72 LANDSCAPE RAKE, 1,250 LB 55 GAL DRUM BALLAST, 2018 FERRIS IS 700Z, 26HP 810 VANGUARD ENGINE
Has anyone with a CK 3510/4010 got the Linked Peeal Kit?
   / CK 3510 "Linked Pedal Kit"..... Anyone? #2
Our neighbor has a 3510 with the linked pedal kit and loves it.They bought it from Michigan iron & equipment.I wish they had a after market kit for my DK40 hst.
   / CK 3510 "Linked Pedal Kit"..... Anyone? #3
I wonder if it would fit?
   / CK 3510 "Linked Pedal Kit"..... Anyone? #4
What does a linked pedal kit do for these tractors?
   / CK 3510 "Linked Pedal Kit"..... Anyone? #5
On hydrostat tractors, it allows the operator to set the manual throttle at a lower level, then when pressing a hydrostatic flow pedal, the linked pedal function will run the engine throttle up as the hydrostat load on the engine increases the rpm of the engine also increases. As the operator releases the pedal and it returns to neutral, the rpm of the engine drops again to the preset level set by the manual throttle control lever.
Hhmmm the resson I ask is because I purchased my CK3510 in the summer and paid for the linked pedal kit at the time of purchase....... the dealer told me they haven't received the link pedal kit from Kioti yet. The dealer has been great and has picked the tractor up twice for service and came to install a kit for the rear remotes. He is 2.5 hrs away and never once charged me for pick up or delivery. ..... so I don't think he would be trying to screw me over for a $128.00 item. If the kit is available at this time I'm sure it just something that got overlooked in my case. I will call Kioti direct and just make sure 100% and then give the dealer a call.
   / CK 3510 "Linked Pedal Kit"..... Anyone? #7
They were in the same boat paid up front kioti finally delivered to MIE about a month ago and they came to their house and installed it on site.
   / CK 3510 "Linked Pedal Kit"..... Anyone? #8
   / CK 3510 "Linked Pedal Kit"..... Anyone? #9
It might, same pedal setup.
Now I'm interested, have to look into further
I spoke with Bob at michigan Iron according to him they will NOT fit the older model Kioti tractors.
   / CK 3510 "Linked Pedal Kit"..... Anyone? #10
I'm in the process of installing the link pedal kit on a CK 3510 H with a field cab (bit of a pain) bought the kit from Michigan Iron, Denise and Bob are great people to deal with, also putting on the cruise kit, arm rest and the beacon. Beacon kit is great considering you need it if running down the road as well as smv sign beacon kit includes base switch wire and relay great deal but no horn on the tractor;strange, wiper, running lights, head lights, signals, seatbelt but no horn or brake lights
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52748)
2014 Doyle Dry...
48" Skid Steer Pallet Forks  (A52384)
48" Skid Steer...
GENERAC ST20-S 2IN WATER PUMP (A52472)
GENERAC ST20-S 2IN...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
2024 BRAZOS  53FT ALUMINUM STEP DECK (A52472)
2024 BRAZOS 53FT...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
