CK 35 HST Dash lights
   / CK 35 HST Dash lights #1
worthb
Bronze Member
I have a 2014 CK 35 HST. If I am reading the owners manual correctly, I should have a 4wd and a differential lock lamp that light up on the dash. Do these lights work on anybody else's tractor? This is bugging me!
   / CK 35 HST Dash lights #2
kioti doesn't have an online parts website like other manufactures
googling for "kioti online parts daigram"
parts diagram, but unable to zoom in close enough to the dash
Error
looks like there are some wiring harness connections that you might try unplugging, and plugging back in.
Thank you for the link. I will tear into my dash soon. I just wondered if anyone else's lights worked.
   / CK 35 HST Dash lights #4
I wouldn't tear into it just yet.. I have never heard of the differential lock lamp, and why would you need one? Would you not know if you heel was pressing in and holding in the differential lock pedal? and my DK has a 4wd lamp, but I am not sure the CK series does as it is mechanically engaged not electrically engaged like my DK. Also keep in mind the dash on the CK is used for several models of tractors and several country variations, so if you see something in the dash does not necessarily mean it is actually hooked up in your model. I would ask the dealer, or look at some on the dealer lot if you can find one.
   / CK 35 HST Dash lights #5
I have a 2004 model year CK30hst and it doesn't have those indicators. As k0ua mentioned, mine has some spots for indicators that have no bulb nor sending units to make them work if they were there.
Thanks for the replies. I keep forgetting that this tractor is built for other countries also. Those lights may be only for the European models. I also noticed that the 30 and 35 dashes are different in the manual. I plan to tear into it anyway soon to install a horn button and loosen up the throttle a little.
   / CK 35 HST Dash lights #7
I have a horn on mine, thought all ck35's had them.
The manual says only European models. I have seen s DK with a horn. It was a Bobcat 440.
   / CK 35 HST Dash lights #9
All of the DK's have a horn up by the battery, and the button is in the center of the combination switch. The turn signal and light switch.
   / CK 35 HST Dash lights #10
I have a 2014 ck35, bought it in NJ, it has a horn. I did read that the horn is on European models, wonder why I have one. Glad I do though.
2021 Hyundai Elantra SEL Sedan (A50324)
2021 Hyundai...
750 Gallon Concrete Fuel Tank (A50774)
750 Gallon...
2011 Hyundai Sonata Sedan (A50324)
2011 Hyundai...
2011 Volvo Semi Truck (NOT RUNNING)(TITLE) (A50774)
2011 Volvo Semi...
2012 Infiniti G25 Sedan (A50324)
2012 Infiniti G25...
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
