CK 30 OIL CHANGE 100 HRS.
   / CK 30 OIL CHANGE 100 HRS. #1
DIRTCUTTER
New Mexico
CK30 HST
Am at 95 hrs on my ck30 the book says I dont have to replace the oil filter at 100 hrs. Any ideas about this out there, by the way am going to use DELO 400 15/40. Which brings me another question at 50 hrs service I use a 15/30 oil I got at tractor supply ,was that ok and is the Delo 400 a better way to go.
   / CK 30 OIL CHANGE 100 HRS. #2
I always change the oil filter when I change the oil, it is really cheap. I also have used delo400 15-40 since change #1. The manual actually calls for a thinner 10-30 oil but my climate is very moderate.
   / CK 30 OIL CHANGE 100 HRS. #3
Change the filter. Cheap, easy and worth every penny in the years to come.
DELO is very good oil.
Bob
   / CK 30 OIL CHANGE 100 HRS. #5
I'm the odd man out with my RedLine 10w-30 synthetic...and a Kioti filter.
I also dose my diesel w/ PowerService fuel additive.
www.redlineoil.com
   / CK 30 OIL CHANGE 100 HRS. #6
www.redlineoil.com
After doing several years of research and working every day with several ASE Certified Master Techs, I'm with you. It may not surprise you that many of the ASE Master Techs also moonlight fixing cars and setting up race cars. From my personal experience in race conditions and seeing abusive conditions, I'd rank Red Line, Royal Purple and Amsoil head and shoulders above any other oils available. Only Mobil comes close, but I wouldn't put it in the same league.
Personally I don't understand people who will spend thousands on an engine and then put the cheapest oil they can find and either put on a worthless Fram filter or not change the filter at all. Even if you drive an econo-box car or an off brand tractor, it's worth your trouble to at least protect what what you've spent. If you drive a high mileage car, an off brand car or tractor, I see even more of a reason to use quality oil.
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2016 BOBCAT MT55 STAND ON SKID STEER (A51242)
2016 BOBCAT MT55...
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
2017 Kubota SVL95-2S (A47384)
2017 Kubota...
John Deere 843 Corn Head (A50514)
John Deere 843...
(3) UNUSED FUTURE JUMPER CABLES (A51243)
(3) UNUSED FUTURE...
