Aug 5, 2022 / CK 30 HST losing rpms after a couple of minutes. #1 RedRocker Veteran Member Joined Apr 28, 2004 Messages 2,188 Location Bowie TX Tractor Kioti CK30 HST, dual remotes, FEL. It acts like fuel starvation, air & fuel filters are good and it runs good for a few minutes, then the rpms drop & will barely move. What other parts could cause this?
Aug 5, 2022 / CK 30 HST losing rpms after a couple of minutes. #2 Robin Veerman Veteran Member Joined Jan 19, 2018 Messages 1,086 Location ONTARIO Canada Tractor 2014 Kioti CK30HST Change the fuel filter if not done so recently, and clean out the fuel line. Could be dirt at the fuel pickup in the tank. Hopefully it's not the dreaded Fuel injection pump issue for the model years 2005-2008? Repair Common Kioti Mechanical Injection Pump Failure What years had bad ip gear
Aug 5, 2022 / CK 30 HST losing rpms after a couple of minutes. Thread Starter #3 OP RedRocker Veteran Member Joined Apr 28, 2004 Messages 2,188 Location Bowie TX Tractor Kioti CK30 HST, dual remotes, FEL. Thanks Robin.
Aug 5, 2022 / CK 30 HST losing rpms after a couple of minutes. #4 Robin Veerman Veteran Member Joined Jan 19, 2018 Messages 1,086 Location ONTARIO Canada Tractor 2014 Kioti CK30HST What year is your tractor? How many hours on it?
Aug 5, 2022 / CK 30 HST losing rpms after a couple of minutes. Thread Starter #5 OP RedRocker Veteran Member Joined Apr 28, 2004 Messages 2,188 Location Bowie TX Tractor Kioti CK30 HST, dual remotes, FEL. 2003 801 hours.
Aug 19, 2022 / CK 30 HST losing rpms after a couple of minutes. Thread Starter #6 OP RedRocker Veteran Member Joined Apr 28, 2004 Messages 2,188 Location Bowie TX Tractor Kioti CK30 HST, dual remotes, FEL. Fuel pump was the culprit, appreciate everyones comments.
