Oil & Fuel CK 30 Fuel Gauge Problem
   / CK 30 Fuel Gauge Problem #1
Grant1
Bronze Member
Middleburg Fl
Kioti CK30, Kioti DK45hst
Has anyone had any problems with their fuel gauge? Mine reads full atall times.
   / CK 30 Fuel Gauge Problem #2
Mine does that sometimes, I don't think the fuel gauge is their strong point.
   / CK 30 Fuel Gauge Problem #3
Mine will read full for a long time and then go down quickly. I know where I am most of the time though, so it's not a problem. I've seen this on most every tractor I've ever used.
If yours is staying on full when it's below half a tank, I'd have the dealer check it out under warranty.
John
   / CK 30 Fuel Gauge Problem #4
I suspect fuel sending unit problem.
   / CK 30 Fuel Gauge Problem #5
My CK30 is almost three months old with 17 hours. The first time I filled it up full it stayed there for a while. Thought it was stuck. Finally it came down to about two thirds and read good the rest of the way. When mine is at 1/4, the tank will take five gallons and be topped off. Sort of makes it easy and gives me a good cushion before running empty. I also use the hour meter. With varied jobs, mine seems to use a gallon per hour.
If yours it at full all the time, even when the fuel is down, call the dealer. You may need a repair. Other members have posted that their gauges aren't always accurate but yours seems bad.
2004 John Deere 6220 (A52128)
2004 John Deere...
2012 INTERNATIONAL WORKSTAR 7500 (A52472)
2012 INTERNATIONAL...
UNUSED MOWERKING SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED MOWERKING...
UNUSED CFG Industrial MX12RX Mini Excavator (A47384)
UNUSED CFG...
2010 Astec Underground RT660 4WD Trencher (A50322)
2010 Astec...
LG 60" PIN ON WHEEL LOADER FORKS (A51242)
LG 60" PIN ON...
