3-Point Hitch CK 25HST 3-Point Hitch Stuck in up position
   / CK 25HST 3-Point Hitch Stuck in up position #1
jsharrard
Oregon
Kioti CK25 HST
I left my 3-Point hitch in the full up position (no implement attached) after parking the tractor in the garage about a month ago. This last weekend, I started up the tractor and let her fully warm up and then prepared to attach my carryall to the 3-point hitch. The hitch will not lower at all even with 250 lbs of weight applied to the arms. The control lever seems to be working normally and I can see that the linkage is operating at it enters into the transmission case.
Everything else seems to be working fine. No strange noises.
Any ideas ?
Regards,
John Sharrard
   / CK 25HST 3-Point Hitch Stuck in up position #2
Did you try to turn the valve between you legs when on the seat?
   / CK 25HST 3-Point Hitch Stuck in up position #3
A lot of us have had that experience. /forums/images/graemlins/blush.gif As mentioned by Rick Wallace, there is a valve at the back of the deck, just where your heels are while sitting, that adjusts how quickly the 3PT hydraulics release pressure and let the arms down. That should do it.
   / CK 25HST 3-Point Hitch Stuck in up position #4
If the valve isn't the problem check the draft control. If you pulled it all the way back by mistake the arms won't lower.
The valve was the culprit. Somehow the valve had gotten totally shut off. I'd completly forgot about it even being there since I'd done my original set up with the brush cutter. I normally just have it cracked open for a slow drop but maybe I turned it closed with the heel of my shoe.
Thanks for the help.
   / CK 25HST 3-Point Hitch Stuck in up position #6
That has happened to me more than once, so don't feel alone.
   / CK 25HST 3-Point Hitch Stuck in up position #7
Happens to all of us. Live and learn.
   / CK 25HST 3-Point Hitch Stuck in up position #8
   / CK 25HST 3-Point Hitch Stuck in up position #9
/forums/images/graemlins/blush.gif /forums/images/graemlins/crazy.gif /forums/images/graemlins/grin.gif
   / CK 25HST 3-Point Hitch Stuck in up position #10
welcome to the pack /forums/images/graemlins/smile.gif
CASE TV370B SKID STEER (A51242)
CASE TV370B SKID...
2021 CATERPILLAR 302.7CR EXCAVATOR (A51242)
2021 CATERPILLAR...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
2009 Chrysler Sebring (A50324)
2009 Chrysler...
2013 Cadillac ATS Sedan (A50324)
2013 Cadillac ATS...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A52128)
2003 International...
