CK 20 Noise at startup
   / CK 20 Noise at startup #2
70 - 80% of the time my 2006 CK20 gear will make a loud squealing/screeching sound at startup. Lasts about 5 to 15 seconds. Comes from forward of the operators seat.
Here is a link to a video. http://www.steveschriber.com/kioti_noise.wmv What do you think?
Steve
Good Grief, I leaned into my speakers in preparation of deciphering the sound from normal sounds. Didn't need to do that, lol. Easy thing first. Hows your fan/alternator belt doing? How free does your water pump feel? This could be belt slippage. If not, we'll move on to your hydraulic system.
   / CK 20 Noise at startup #3
And welcome back to the forum
   / CK 20 Noise at startup #4
I agree with xcgreene. That looks indeed like the fan belt slipping. Probably caused by the alternator producing more current to charge the battery after the starter consumption.
I would remove the tension from the belt, put it aside and check for weird noises that could come from the bearings of the alternator and water pump/fan.
   / CK 20 Noise at startup #6
IMO, you need to check the belt tension (and correct it if it's off) before doing anything else.
   / CK 20 Noise at startup #7
I'll add my voice to those saying check the belt. the user manual outlines how much tension and how to check it/adjust it. (I can help out if you don't have yours.)
How long has this been going on?
E.
   / CK 20 Noise at startup #8
If the belt has glazed even tensioning it may not help.
You could remove it then start and see if the noise is gone, if so then check all rotating components and replace the belt.
Thanks everyone. Come to think of it it usually doesn't happen on initial cold start. I will check belt tension.
2022 Heli Forklift (A51573)
2022 Heli Forklift...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
East Tri Axle Semi Dump Trailer (TITLE) (A50774)
East Tri Axle Semi...
2013 Nissan Pathfinder SV SUV (A50324)
2013 Nissan...
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
David Bradley Manure Spreader (A50515)
David Bradley...
