CK 20 - More power?
   / CK 20 - More power? #1
lcisled
First off - this is not a thread to complain about the CK20H.
Overall, this is not a bad tractor. I would just love to have about 5 more hp for PTO implements. Looked to trade it for same size chassis, more power and I constantly get told it is a throw away tractor (only worth $6500, etc.) and they want $10K to trade. I can sure do a lot with a wrench for 1-3 K for add ons and get what I want.
Anybody ever thought of doing some changes to the motor to get more power out of it?
Obviously I am out of warranty and thinking of doing some tinkering to get more power. Wondering if anybody here thought about pump improvements, etc. Something along the same lines that happens to diesel pickups,etc.
What made me think of it is that when looking at different makes of tractors they use the same size motor and put out different power (JD 3120, JD 3320, JD 3520, JD3720).
If you have something constructive, I would love to hear it. If you don't, please keep it to yourself. I know they set them up from the factory, blah, blah, blah. I know any more power and I will tear the driveline out of it, blah, blah, blah. I am willing to pay the price to get some more out of it in a custom type of way.
Anybody tried it and found different injectors, pumps, etc. somewhere that I can try?
   / CK 20 - More power? #2
good question...wish i had an answer...I think the 3320 (one I own) is a bit different than the others listed...I remember looking into that..it has a slighly more displacement..but less power than the 35/37. I chose that cause I tend to run at less than PTO RPM. The higher HP models are smaller but have turbos, one small, one bigger. (This is from memory..and maybe bit off.) There are some here that have added turbos to not-turbo engines. It does seem to take some work. It may not be the easiest but big on the cool factor.
   / CK 20 - More power? #3
That is a good sized budget.....I think you should consider turbo charging it.
There are a number of threads on TBN about just that subject and some
posters have successfully done it to various makes of CUT.
As long as you don't go nuts with over say, 10psi of boost, you should be
OK. You will prob need to go up in injector flow before you reach that
boost, however. You should be able to get 25% better power with a
conservative set-up.
The CK20 is an excellent tractor, but I agree it needs more power. If you
decide to sell it, don't trade it in!
   / CK 20 - More power? #4
Hmmm..... You're talking a lot of work and expense to get a few more hp out of that tractor. Trading it in is a losing proposition. A Kioti dealer would give you the best trade in value, I'd think.
Me, I'd sell it privately and buy what I really need. If you want to stay in that size frame, there are few choices that will give you more hp: some kubotas, deeres, and the TYM T273. The TYM is a very nicely sized machine, but will also suffer in the resale value game. Just be deliberate and make sure you get enough tractor the second time round so you're not facing the resale value dilemma again.
If you do decide to turbo or whatever, it will be interesting to follow. Please post your progress for all of us to read. Good luck.
   / CK 20 - More power? #5
One of the quickest, easiest ways to get MORE POWER is to just change all fluids to high quality synthetic fluids. The next step I would investigate is find out the injection timing, and if possible advance it a bit. Next step is of course to have the injection pump recalibrated, and install a bit larger injector nozzles, or larger injectors. Then there is the turbo route, but turboed engines usually have a different piston, especially the top of the piston is configured for a turbo. Hope this helps. I would figure with just the oil changes, a 1hp gain engine wise, but an additional 1hp pto gain also. Good luck. :) Use power service also, it boosts the centa rating of diesel fuel.
Thanks for the replies.
As I said, I looked at the other tractors - all are either wider or longer wheelbase, do not have the options (position control vs. quarter inching, no independent circuit for the rear hydraulics, lower ground clearance, etc.), and then they think they want $10K to trade (or 18-20K to buy outright if I did sell my tractor-after what I bought this for, they are not showing me the value).
So, to be truthful, that option is out, not only for the money, but the undesirable options on the other tractors.
I can go synthetics, but not sure that is going to get me where I want to go.
We have a good diesel injection shop near here. I am thinking about taking it there and having them give it a tune and a boost if possible.
A turbo would be the step after that, but I am not sure I want to go there.
Anybody done any mods and know where to get parts (bigger injectors, turbos, intercoolers, etc)?
   / CK 20 - More power? #8
I don't think this is true for the TYM T273. New with loader were being sold recently for under $11K. The wheelbase is about 10" SHORTER than the CK20. Better specs in just about all areas over the CK20. They have true position control too. Not sure about rear hydraulics; I think one set of rear remotes are standard. PTO is electric over hydro like the DK's. Hydro tranny, QA loader, and mid PTO are all standard.
But, what about buying used? For example, a used TYM is for sale near me with just 75 hours. They are asking $8500. Sell yours and find one of these for near even money. Also, Montana sells this same tractor under their badge. Not many other brands that fit the same characteristics as the CK20, though.
Wish I could offer suggestions on increasing HP of the CK20. I just don't know how. I may be naive, but I'm doubtful you'll be able to get what you want/need with mods and add-ons.
   / CK 20 - More power? #9
To me, sell it private and buy larger. Mod's will never make you as happy as a bigger tractor and seem like a lot of effort. They might cause it to lose resale too as that sort of thing scares me away from stuff. I don't know exactly what work you want to do, maybe if you shared some folks would have alternate ideas for your issues outside of more HP.
On the other hand, maybe it will increase the resale appeal. Tough time to have to sell or trade.
Good luck.
   / CK 20 - More power? #10
I did a DK40se modification to my CK20 which doubled the power and got 250% upgrade in loader power at the same time. For directions on how to do this modification just give your dealer a call. ;)
1992 Ford Explorer (A50515)
1992 Ford Explorer...
New Holland 900 Chopper (A50774)
New Holland 900...
M & M Grain Drill (A50515)
M & M Grain Drill...
1975 Dodge 600 Grain Truck (A50514)
1975 Dodge 600...
Rears 1000 Gallon Orchard Sprayer (A50120)
Rears 1000 Gallon...
2003 Ottawa Spotter Truck (A50120)
2003 Ottawa...
