CK 20 front axle oil
   / CK 20 front axle oil #1
grizzlydave
sw Pa, just north of morgantown
dk55 , ck20s
Hi everyone , In the manual it calls for 90w gear oil in the front axle ! I've been everywhere tsc, napa, autozone, walmart and southern states and no one has 90w oil ! Where do you get it ? Or will 85w-135 work ? I have used utf or 135 in all the other tractors ! Thanks for any help
   / CK 20 front axle oil #2
The oil in stores is typically called 80W/90.
TSC should have it in the Traveller and probably other brands.
Most any automotive store will have it.
The old manuals said we could run hydraulic oil or 80W/90 in the front end.
I prefer the UTF myself, I would not run the 85/135 or 85/140
BTI
   / CK 20 front axle oil #4
The reason given to me was that so many people insist on running 80W/90 that they had to change the manual.
They completely dropped the UTF
I do know that when I used to tell customers they could run UTF they always gave me a weird look.
I would then explain that there's not alot of difference between whats in the front end and in the rear end (parts wise).
One less oil to buy....
BTI
   / CK 20 front axle oil #5
BTI
UTF also will flow and lubricate better in cold weather.
   / CK 20 front axle oil #6
To speed up the fill process remove one of the top caps on the pivot housing.
It's a much bigger hole than trying to use one of the fill plugs on the axle case.
   / CK 20 front axle oil #7
A few months ago I was told by Bobcat that this question was asked of Daedong, customers were noticing that front axle oil drained at the 50 hr. service did not appear to be 80-90w and looke like same as in rear/hydraulic fluid. Daedang said either is OK, they use UTF (transmission/hydraulic fluid) in assembly for commonality. After introducing tractors to the US they added 80-90w to the list per customers request - meant to list it as either is OK, but something got lost in translation of the manual. 80-90w is a little less expensive, but if it is more convinient to use 1 oil in both axles it is OK.
Wish I would have known this before I did my 50 hr. service. Would have been a lot simpler to get extra gallon of hydraulic fluid and keep on hand in case of leak later.
I didnt even notice it in the manual until i checked to see how much fluid it took ! I will just run the utf in it always have any other tractor never had an issue ! Best part of it is thats 1 less oil type i have to stock :confused2:
   / CK 20 front axle oil #9
In the spirit of worrying about nothing, the Shell Spirax UTF I have the 50hr service only has a GL-4 rating. Really I see no reason why you wouldn't want a GL-5 rated oil up there, as the front axle sees lots of low speed and high torque usage.
Here's what lubrizol has to say about the oils:
API Category GL-4 designates the type of service characteristic of spiral-bevel and hypoid gears in automotive axles operated under moderate speeds and loads. These oils may be used in selected manual transmission and transaxle applications.
API Category GL-5 designates the type of service characteristic of gears, particularly hypoids in automotive axles under high-speed and/or low-speed, high-torque conditions. Lubricants qualified under U.S. Military specification MIL-L-2105D (formerly MIL-L-2015C), MIL-PRF-2105E and SAE J2360 satisfy the requirements of the API GL-5 service designation.
API GL-5: Clearing up the Confusion - Automotive Gear Oil Additives - Driveline Additives - The Lubrizol Corporation
The GL-4 description doesn't really sound like a front tractor axle to me... But my dealer says the UTF I have is fine anyways. I haven't decided yet if I'm going to get a GL-5 gear oil for the front or not, maybe if I find some on sale it will be a no brainer.
NEW LandHero Mini Stand up Skid Steer (A53002)
NEW LandHero Mini...
2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL1DL085200 (A51572)
2013 International...
2021 PETERBILT 389 MID-ROOF SLEEPER (A52472)
2021 PETERBILT 389...
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
