City Bound, Kubota M62 Tractor Loader Backhoe, EA Box Blade, and EA LandPlane For Sale
Item Details
Type
Year
2016
Condition
Used
Price
72500
Make
Kubota
Model
M62
Hours
630
California
Item status
  1. Sold
Marketplace Terms & Conditions
  1. I have read and agree to the rules and terms of use
Note: TBN is displaying "Sold" as the status of the tractor, but it is still for sale. If this ad is still up, the Kubota is still for sale!
I've moved back to the city and need to sell my farm equipment.
Each item is listed with the current MSRP price as of 3/28/2025 and my asking price. The equipment is located in Butte County, California in the 95965 zip code, above the Feather River Canyon in a tiny settlement called Yankee Hill. Please contact me at general@gunsmoke.com if you have any interest.
The M62 is part of Kubota's construction line of machines, and is built much more robustly than its agriculture line.
Quoting Kubota:
Engineered to save you time and effort on every job. Packed full of upgraded features, this M62 comes equipped with a 63 HP Kubota Tier 4 Final diesel engine, Kubota front loader with 3,960 lbs. of lift capacity and strong Kubota backhoe with 169.8 in. max digging depth. It's one powerful combination ideal for a wide range of landscaping, construction and contracting jobs.
Features Include:
The Diesel engine is equipped with a regeneration based pollution control system that doesn't require Diesel Exhaust Fluid (DEF).
The hydrostatic transmission has three forward speed ranges and one reverse, with speed and direction controlled by a single rocker style foot pedal. Power steering is standard, so this is a very easy to run machine, almost as simple as driving a car.
The front end loader is fitted with a pair of hydraulic ports that can power a 4-in-1 bucket or grapple.
Unlike most TLBs out there, the backhoe is easily removed and three point hitch lifting arms can be installed to allow the use of box blades, scrapers, rippers, and other ground engaging implements.
The three point lifting arms are fitted with Pats Quick Hitch to make mounting and dismounting three point implements much easier.
It's also fitted with a power takeoff at the rear, so it will run rotary and flail mowers, augers, generators, , and other three point implements.
There are three pairs of hydraulic ports on the rear of the tractor that can power the two cylinders on the Top'n'Tilt, a side shift cylinder on a mower, and other hydraulic implements.
The backhoe is fitted with a foot pedal controlled thumb so trees, rocks and whatever else can be grasped and lifted easily.
The 12" and 24" backhoe buckets are fitted with quick attach so changing between the two is quick and easy.
Six inch spacers are fitted to the rear wheels for added stability and safety when operating on steep grades.
This TLB was made in 2016 and has about 630 hours on it. The hours will continue to accumulate as I use it to maintain the property here. All maintenance is up to date, and everything works as it should.
The only damage is the plastic surround in front of the radiator, the cracks in which have been wired back together.
The only thing that annoys me about this tractor is the operator presence switch in the seat, which, when the tractor is underway, will turn off the engine ignition if my weight isn't squarely centered in the seat. It doesn't happen often, but it's annoying when it does. I don't weigh a lot (155 lbs. soaking wet), and pushing down on the differential lock or turning around so I can watch a box blade or scraper is when it usually happens. Lifting my foot off the go pedal will resume engine function before it quits all together.
This tractor is heavily accessorized as indicated in the list of options below.
Kubota Add-Ons installed on this tractor:
Backhoe w/Auxillary Hydraulic Valve / M62TLB MSRP: $23,541
(BT1400)
1 2”4 QUICK ATTACH TRENCHING BUCKET $1986.00
(K7875 for excavator quick attach) - correct bucket
(BT4582 for BT1400V backhoe quick attach)
1 12" QUICK ATTACH TRENCHING BUCKET MSRP: $23,541$1467.00
(K7872 for excavator quick attach) - correct bucket
1 84” QC HEAVY DUTY ROUND BACK BUCKETMSRP: $23,541 $1,597.00
(19.1 cu. ft. struck) (23.57 cu. ft. heaped)
336 lbs.
(TL3421A)
Came installed on the M62 tractor
2 RUBBER SHOE,MSRP: $324.00
(L9467)
1 HYDRAULIC THUMB ( FOR Q.C. BUCKETS), MSRP: $3,878.00
(K7545)
1 QUICK ATTACH COUPLER / BT1400(V) /BT1000B(V),MSRP: $880.00
(K7543)
1 TOP-N-TILT KIT,MSRP: $1157.00, requires L3995A
(TL9407A)
Includes 2 cylinders, 4 hoses, quick connect fittings, and hose end fittings
1 REMOTE VALVE KIT FOR REAR ATTACHMENTS MSRP: $2,952.00
Consists of 3 Float Detent Valves, L-Series Style Female Quick Couplers, Quick Couplers mount on Right Side Rear ROPS Post, Three Control Levers directly connected to valves. L3995A valve kit is required for installation of the TL9407A Top-N-Tilt kit.
(L3995A)
This was returned because the spools leaked. It was replaced by a better set of spools from Fit Rite Hydraulics.
1 3P LINKAGE KIT / M59TLB, MSRP: $959.00
Includes left and right lift rods, pin set, 1 pair lifting arms, top and side links, and comp, rubber.
(L3951)
The MSRPs quoted above are as of 3/31/2025.
Base Model Kubota M62 MSRP: $48,649
Kubota Add-Ons $48,014 (See above)
Total MSRP $93,675
Sell Price $72,500
My sell price is 75% of the MSRP price, and does not include shipping. This will be a private party sale, so there is no dealer mark up and no sales tax charge. I will accept a bank wire transfer, and unfortunately there will be a delay until the bank assures me that the transfer has cleared. If the buyer would like to use an escrow service, they will be responsible for all associated costs. If you're local to the 95965 zip code, we can meet at the bank of your choice to have a bank draft drawn.
I'm flexible in pricing if you want more than one item.
No trades.
Cash, escrow, or bank draft only.
First come, first served. Will not hold.
Will not respond to "is it still available" inquiries or low ball offers.
I'll be updating this ad as items are sold off, so if the ad for an item is still up, the item is still for sale.
Everything Attachments TA-CATI-II-XDBBV2-84 V2.0 84" Category I & II Severe XTreme Duty Box Blade
Category I & II Severe XTreme Duty Tractor Box Blade - Everything Attachments
$2550 new, $1675 sell price
Everything Attachments Land Leveler-Land Plane for Category 1 & 2 Hitch Version 2.0
Dual Edge Land Leveler Land Plane Utility Grader V2.0
$3125 new, $2075 sell price
   / City Bound, Kubota M62 Tractor Loader Backhoe, EA Box Blade, and EA LandPlane For Sale #2
What is the M62 rear wheel spacers length? Looks to be 4".
2024 Dig Master DM100 Mini Excavator, NEW! (A52384)
2024 Dig Master...
2020 Kinze 3505 High Speed 6/11 Planter (A53473)
2020 Kinze 3505...
2019 Cat 914M Wheel Loader (A52384)
2019 Cat 914M...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
2001 CATERPILLAR IT28G (A52472)
2001 CATERPILLAR...
2015 Top Hat T/A 20 ft. Gooseneck Trailer (A53117)
2015 Top Hat T/A...
