Church got me but have you seen this before?
   / Church got me but have you seen this before? #1
ArmyPair2
Alabama
NorTrac/40XT
:confused3:Me and the wife's church have a agreement where they leave me alone but when they need help I will help them out. During the summer I will build them something for their summer vacation bible study for the kids and in the winter I will build them a Christmas Float for the Parades. A few days ago the church dropped off a trailer that is 8 x 16 so I can build them a float once they come up with a idea for the parade and singing carols.
When the man that dropped off the trailer he said he had problems with the taillights and I said I will take a look at them. Before he left and I am glancing at the cables he said he had a small squirrel problem and I wanted to say something that would have offended him. Now before some of you super regulars tell me to do a search I did but nothing I could find on this so that was a no-go. I bought a new pig tail to replace the one that was all chewed up but that still did not fix the problem.
I got the right side working just fine and it did all the signals but when I went to trace the left side I found he had what looked like a speaker cord used for a jumper wire with the ends cutoff that went to the left side After all that time doing research on what color wires did what and I got it to work almost all the way. Everything almost works but when you step on the brake lights the left side goes dark. 3 wires come out of the left light Brown taillight ,White ground and Yellow for left turn. For me this tells me there is a short to ground problem and this being my first trailer it tells me the light housing or a bulb or a bare wire is causing this problem
Any ideas because I am almost to the point of buying a new wiring harness and taillights just to be left alone from her church and I only have 3 days left to get the trailer ready. Everything works but step on the brake and the left side taillight goes out. SHHHHH PS I did tell my wife that I needed a Milwaukee 15 amp 7 1/4 saw to cut out wood to build seats on the float. I don't work for free but she always tells me that I am on a guilt trip from what I always put my Army Chaplin's through.
   / Church got me but have you seen this before? #2
I'm just thinking there is a very sad story here.
But, good luck with the trailer.
   / Church got me but have you seen this before? #3
Sounds like you have a bad ground at the light that goes out. Not enough ground to run both tail and brake light. Most tail lights ground with one of the mounting studs. Clean them and make sure they are tight.
sscrob forgot the update and your 100% right when I got a chance to get to see the trailer in daylight I found a bolt on the tongue with a few wires sticking out where the ground should be and my guess would be he was using the ball hitch as the only ground to trailer but after taping close to 20 bare wire spots on the cables I just got tired of it. What I did was and seeing this float was for the church I drove into the city and bought a new light system for the trailer.
Before I installed the new setup I made sure to grind all the points that needed a good ground and everything worked like a champ when all setup. When Mr. Bob came for the trailer he asked me how much does he and the church owes me? I told him nothing because I got a new Skill Saw out of this project. My wife almost busted me when she said "but I thought last year you needed a new table saw to cut 2x6's to make seats".
It all turned out good because the kids had fun and I got another power tool out of it but if my old Army Chaplin's could see me now they would just crack a smile at me and try to bless me.:thumbsup:
   / Church got me but have you seen this before? #5
Glad it worked out.
   / Church got me but have you seen this before? #6
Where's the parade picture?
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
Ford NAA Jubilee Tractor (A51039)
Ford NAA Jubilee...
2023 TAKEUCHI TL10V2 SKID STEER (A51242)
2023 TAKEUCHI...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
1993 Ford Ranger STX Ext. Cab Pickup Truck (A50323)
1993 Ford Ranger...
2013 Dodge Journey SXT (A50324)
2013 Dodge Journey...
