Chrome piston replacement on 7108 loader
/ Chrome piston replacement on 7108 loader #1
B Rive
Putnam Valley, NY
Ford 1620
I have a Ford 1620 with a 7108 front end loader. This weekend I was using it and noticed that the piston that tilts the bucket was leaking and the chrome was chipping off the shaft. How difficult to rebuild and where would you recommend getting the parts from. I live in Putnam County, N.Y.
/ Chrome piston replacement on 7108 loader #2
well i think what you mean is the chrome cylinder rod not the piston as these are rarely chromed and you cant see the piston till you disasemble it anyhow. as for repair options i would first price a rod from the dealer, sometimes they arnt too bad, and sometimes they are outa this world expensive like the 12 inch long 25 mm dia rod for my john deere steering that deere wanted 460 bucks for! if a rod is a bit high in price then call around to a few hydraulic shops and see what they want to make a rod for it, usualy this is a much more reasonable option. or if you are a do it yourself kinda guy you can simply buy the chrome stock from a hyd shop or mcmaster carr and make your own rod. rods can be rechromed also, but this is usualy only cost effective on large cylinder rods. the other option if its a small chip is to polish the edges and put in a seal kit and use it as is, often a ok solution if its a limited usage machine not an every day construction rig etc. as long as its well polished the seal wont be damaged and will just leak a little when it goes past that point, but very minute amount if any realy
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
(INOP) 2012 CHEVROLET TAHOE (A59823)
(INOP) 2012...
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
Crabtree 14yd. Dirt Pan (A64047)
Crabtree 14yd...
SECTION OF PALLET RACKING (A63745)
SECTION OF PALLET...
2022 Kuhn FC4461 TCD MoCo (A63116)
2022 Kuhn FC4461...
