Chpper adjustment
   / Chpper adjustment #1
rd_macgregor
Veteran Member
Prince Edward Island, Canada
Kioti DK45SC, Kubota B2650
I didn't want to hijack the other thread on chippers with my question, hence the new thread. I have a Wallenstein BX62 that I bought last year, but my question is more generic for chippers in general. I'd like to know what the effect of different blade spacing is. Does a slightly wider spacing make the chipper take bigger bites, feed faster and risk jamming more frequently? I presume that a smaller blade spacing would make finer chips, but would it prevent the chipper from self-feeding or cause some other operational problem?
I don't have a feeler gauge, but my Wallenstein apparently specifies a blade setting about halfway between the thickness of a dime and the thickness of a hacksaw blade. How precisely do others set their blade spacing (relative to what factory spec is)?
Thanks,
BOB
   / Chpper adjustment #2
I seem to recall that the factory specs are somewhere between 1/32" and 1/16" for my BX-42. I eyeball it to about 1/16".
If the gap is too big, I think the bites will be too aggressive and the chipper will struggle. Too small and it won't be productive. I'll take the factory on their word that between 1/32" and 1/16" is about right. The chipper works darn good at that setting.
   / Chpper adjustment
It sounds like I'm in the ballpark, then, since a dime is just under 1/16" and a hacksaw blade is (usually) pretty close to 1/32".
Thanks,
BOB
   / Chpper adjustment #4
Well I have been wrestling with a Valby 150 for a month now. I think this is about the same size as your BX -62. Self feed, does 6" logs (supposedly!) and the flywheel weight is about 215 pds. When I bought it in Jan and started using it, worked fine until I broke a belt-my fault I had never read the manual on belt tension. So I replaced belts (not a fun job with a 60 lb pulley assembly and a 200+ pd flywheel) and had the knioves sharpenbed-by a pro outfit. worked fairly wellbut would not self feed. I then had the anvils sharpened.
Has not worked well. You can't feed a 3" branch without the vibration ripping it out of your hands. My spec is .020 to .033". And I'm using feeler gauge. I got it down to a reasonable feed but next step is to get the blades sharpened again. US distributor (grest people-Northeast Imp. in Spencer NY) tells me knife angle (30degrees) ismost critical.
My tractor by the way is a JD 4720 with 50 PTO HP. so it is NOT a power issue. In fact one of my kidsused it with his 2520 with no problem hndling 2" stuff.
   / Chpper adjustment
I haven't tried to put anything quite 6" through mine yet, but last year had some issues with green spruce saplings. These are field-grown and tend to be fatter at the base. The first jam stopped the chipper, but didn't shear the pin...worse, it didn't stall the tractor, either; the tractor dropped a bunch of rpms, but kept running, presumably slipping the pto clutch until I could shut 'er down.
The second jam sheared the pin. Since the chips seemed pretty large/coarse, I thought maybe a tighter blade setting would reduce the bite size and feed rate making jams less likely...but I was worried that it might not self-feed anymore.
Having said that, the unit REALLY chews up brush (kind of scary to this newbie [maybe a good thing!]), so it sounds like I'm still a bit better off than you. I hope you get it tweaked to work just right; there are few things more frustrating than a (new, expensive!) piece of equipment that won't do its job as it should.
BOB
2021 ALLMAND BROS, INC. NIGHT LITE TOWER (A50854)
2021 ALLMAND BROS...
Deere 9965 Cotton Picker (A51039)
Deere 9965 Cotton...
2019 CATERPILLAR D6N LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
2007 AM General Corp M931A1 6x4 Truck Tractor (A48081)
2007 AM General...
2014 Range Rover AWD SUV (A48082)
2014 Range Rover...
