choke
   / choke #1
gerwien
keysville Va.
I have a ford 2000 that wont run without the choke on.. anyone have a solution?
   / choke #2
Guessing here, but could be because it's either getting too much air or not enough gas, thus it only runs when you choke the air to get things back in a balance that works. That is, it's running too lean.
I'd check for air leaks(at carb, or between carb & motor) or fuel line blockage issues. Too little gas/to much air will make it run hot, you don't want to burn up a piston.
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2012 Kenworth W900 (HEAVY DUTY) (A52748)
2012 Kenworth W900...
2018 Wacker Neuson WL 38 (A52748)
2018 Wacker Neuson...
2020 Mathieu MC210 Azura Flex Street Sweeper (A51691)
2020 Mathieu MC210...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
2017 GENIE GS-2646 (A52472)
2017 GENIE GS-2646...
