Chlorine Injector - Where To Buy?
   / Chlorine Injector - Where To Buy? #1
Lane
Bronze Member
Anyone have links or names where a chlorine injector system (or parts to build one) for a residential water well can be purchased?
   / Chlorine Injector - Where To Buy? #2
Lane, I have a Pulsatron adjustable chlorine injector pump. This unit is about $350.00. It sits on top of a 20 gallon plastic tank. The pump pulls a 10ppm chlorine mix from the tank and injects into the water line. The injector nozzle and the pickup check valve and screen in the tank are $60.00 each and are made from a nylon composite. I will need to check this for sure but the manufacturer is CUNO, they are located in Indiana. You should be able to get this unit from a local pool suplies distrubutor in your area. You can use either pool chlorine (12%) or Clorox (6%) to mix the injectable. If you have not used one of these before you need to know you have a lot to learn.
Try the Water Source at http://www.thewatersourceltd.com/index.html
Good luck. ric
UNUSED Clear Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Clear...
2016 John Deere 5055E 55HP Utility Tractor (A52377)
2016 John Deere...
2015 Ford F250 Extended Cab Flatbed (A53422)
2015 Ford F250...
2013 MACK CXU613 (A53843)
2013 MACK CXU613...
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
