Chipper on a BX
   / Chipper on a BX #1
Dickb
AA County, Maryland
Massey Ferguson GC2300
Has anyone used one of the 4" Chinese chippers on a BX series Kubota? I have a Massey GC2300 and am concerned about the weight of the chipper. The GC2300 has about the same 3 pth weight capacity as the BX.
   / Chipper on a BX #2
I don't know about the Chinese chippers, but I asked my dealer about using the Woods 5000 on my BX and he said it would be no problem...they've sucessfully run them on machines with as little as 12 PTO HP. He did further talk about the fact that "how" you use the chipper can make a big difference...if you try to force the machine such that it looses momentum on the flywheel, it will require more omph from the tractor.
   / Chipper on a BX #4
I have sucessfully used a Woods 5000 Chipper behind a recently replaced B6100E with 12 PTO hp. Just had to feed the heavy stuff slowly. Go for it!
Vernon
   / Chipper on a BX #5
Bear Cat makes a 4" chipper/shredder that is rated for a 15hp gas / 13hp diesel tractor. It weighs 450lbs and is capable of chipping up to 5in. material. Retail with a 1yr warranty is $2599. I can give you a discount of 8% when you mention that you saw it online. Shipping on these is very cheap. These units have been around for a long time and are assembled here in the U.S. We have been a dealer for them for nearly 20yrs. Call Levi @ 1-800-287-2048 Envirochipper Home Page
   / Chipper on a BX #6
I use a 4" capacity wallenstein bx 40 on my bx2200. As long as you keep the rpm's up it seems to take anything I throw at it. A 22 hp diesel is probably putting out 17 hp at the rear pto. Just about marginal but works OK.
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
FRONTIER SA21G LOT NUMBER 145 (A53084)
FRONTIER SA21G LOT...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A52472)
2014 AMERITRAIL...
