Chicomm Flail Mower vibration
   / Chicomm Flail Mower vibration #1
def38
Platinum Member
woods and mountains of Alabama
M-F 231S
I have had a Titan flail mower for several years now. It cuts OK and seems to be holding up (except for the well documented cracked top link tower brackets) OK.
I have noticed a lot of noise coming from the underside of the mower. I'm wondering what it could be? The bearings and seals seem to be in good order and the flail drum rotates smoothly. I'm thinking that the saw-toothed piece at the top of the mower cabinet that helps the recut may be loose. I need to do a more thorough inspection with mower up on jacks.
Any thoughts? Any of you out there have a few seasons on a similar mower? Mine is attached to my MF which handles it well. The mower has had its share of encounters with rocks and 2-3 inch limbs.
Let me know your thoughts on where I might look for the noise. Thanks.
1999 Ford F450 Dump / Plow Truck (A50514)
1999 Ford F450...
2025 LandHonor UHA-16-3000G 2in Utility Hitch Adapter Skid Steer Attachment (A49462)
2025 LandHonor...
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A51039)
2021 New Holland...
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2014 Ford F-550...
2020 CATERPILLAR 938M WHEEL LOADER (A51242)
2020 CATERPILLAR...
2006 Ford F450 XL Bucket Truck (A47384)
2006 Ford F450 XL...
