Chevron 1000 THF
   / Chevron 1000 THF #1
RNeumann
Elite Member
North Idaho
Mahindra 1538
My Mahindra HST manual has a few choices of hydraulic fluid in the manual. One of them is Chevron 1000 THF. Chevron has treated my engines well but I don't know much about hydraulic fluid.
I see a lot written about Tractor Supply fluid but I don't have that option near me. I have Wally World and the local auto parts stores.
Thanks for the input!
   / Chevron 1000 THF #2
The Chevron fluid might be tough to find. It's also not cheap. I happen to have tried to find 10 gallons of it recently. Price I got was $159 for a five gallon pail. If you're going to spend that kind of money, might look at the Amsoil 5w-30 synthetic hydraulic fluid. Lots of satisfied users here. You can look it up, but I'd be very surprised if it doesn't meet OEM specs for your machine. I got a similar price on the Amsoil, and it was easier to find.
I opted to use Kubota's synthetic hydraulic fluid, SUDT. It was $100/5 gallon pail.
Personally, I don't have any interest in the tractor supply stuff for a HST machine. In some old iron, for sure, but the extra money spent on something better makes sense to me in this application.
   / Chevron 1000 THF #3
Lots written on TBN about this.
I started out in the 90s using Chevron 1000 THF from my local oil disti. It is a semi-synthetic tractor-hyd fluid
with equvalences noted to JD J20c and Kubota UDT. It looks and smells like other equivalent THFs out there.
I have been recently buying the Conoco 76 THF and ServicePro THF, which both have the same equivalences
noted, and smell/look the same.
I pay about $50/5gal for either. Note that Amsoil full-synth will run $150/5gal, and low-vis THFs (J20D and SUDT)
will also run a bunch more than $10/gal. In the cold country, you might have to run low-vis.
BTW, Walmart and Napa stores sometimes sell name-brand THFs, but for a lot more than the oil distis. Sometimes
tractor dealers like Kubota run specials on 5-gal pails of THF. I once found UDT at a Kubota dealer for $55/5gal.
   / Chevron 1000 THF
Ok thanks for the replies. The manual lists a few others.
Citgo Transgard
Exxon Torque Fluid 56
Mobil Mobil Fluid 424
Texaco THD oil Special
Any info on these? Amsoil is out for me.
   / Chevron 1000 THF #5
with equvalences noted to JD J20c and Kubota UDT. .
If the Chevron oil is equivalent to J20C just about any universal hydraulic oil will surpass that spec. Since you are in Idaho, I suspect that you will want to use your tractor to clear snow in the winter and thus will need a super low viscosity fluid, something thinner than the J20C. I would look at using a full synthetic like the Kubota SUDT2 or similar spec'ed oil.
   / Chevron 1000 THF
Thank you for the advice. I guess I have a lot to learn on this subject. All of this is foreign to me- especially stuff that isn't in the manual but seems to work for folks. I didn't even realize the hydraulic fluid came in different viscosity.....
   / Chevron 1000 THF #7
Citgo Transgard
I'm surprised they list any options other than their house brand. What you need to do is look at the specification that they require for their fluid. For example, my NH needs the fluid to me meet a spec that they call NH134D. There's tons of oils that meet the spec, but New Holland won't list them all. Look for what the spec is in your manual. Then see if the Amsoil meets that spec.
Here's what the Amsoil meets:
SPECIFICATIONS
AMSOIL Hydraulic/Transmission Oil is recommended for transmission and hydraulic applications that require any of the listed specifications. Consult your owner's manual for specific application requirements.
AGCO/Deutz-Allis/Allis-Chalmers – PowerFluid PF-821 XL, 25741, 246634
AGCO White Farm (Oliver) – Q-1826, Q-1802, Q-1766B (UTHF), Q-1766, Q-1722, Q-1705, Type 55
Allison – C4, C3, C2
API GL-4
Case New Holland (CNH) – MAT 3505 (MS-1209), MS-1207 (Hy-Tran® Plus), MAT 3506 (MS-1210) (TCH Fluid JIC-145), MAT 3509 (MS-1230, M2C48C), Poclain Equipment high pressure systems, MAT 3525 (FNHA-2-C-201.00, M2C134D), MAT 3526 (FNHA-2-C-200.00 winter grade), MAT 3510 (MS-1317, GL-4), B-6, MS-1206 (PTF), MS-1205 (TFD-II), MS-1204 (TFD), JIC-185, JIC-144, JIC-143, B-5, M2C86B/C, M2C53A, M2C41B, M2CA/B/C, ESN-M2C77A, ESN-M2C41B, ESNM2C43, ESN-M2C48B/C, ESN-M2C53A/B, ESN-142A, ESN-M2C143, ESN-M2C92A, ESN-M2C159A/B/C, Renk-Doromat 873 or 874A/B Bus Automatic Transmission Fluid, Valtractores
Caterpillar – TO-2
Clark – TA 12, TA 18, HR 500, HR 600
Dresser CED – Trans/Hyd Fluid
Deutz-Allis – 25743, 272843
Deutz-Fahr
Sperry Vickers/Eaton – I-286-S, M-2950-S
Fendt (Non-Vario)
Fiat-Hesston – AF-87
Ford – ESN M2C86B, M2C86C, Fiat requiring M2C134D, FNHA-2-C-201.00
John Deere – J20C, J20D (winter grade), J14A/B/C, JDT303, J20A/B, J121A
Komatsu
Kubota – UDT/M80B
Landini – Tractor Hydraulic Fluid
Massey-Ferguson – M-1141 (Permatran® 821 XL, Formerly Permatran ® III), M-1110, M-1127A/B, M-1129A, M-1135, M-1138, M-1139, M-1143, M-1145
Parker Denison – HF-0, HF-1, HF-2
Sauer Sundstrand/Danfoss – Hydrostatic Transmission Fluid
Steiger – HTF (SEMS 17001)
Volvo – VCE 1273.03, WB101
Versatile – Recommended for use in Valmet, New Idea Power Units, Leyland Belarus, Specs 23M & 24M
ZF – TE-ML 03E, TE-ML 05F, TE-ML 06K, TE-ML 17E
   / Chevron 1000 THF #8
$159 for five gallons.... they got you good.
I pay 70 some bucks for five at my dist, for a pristine new bucket of thf 1000. The refill is even less.
I'm running it in the 790 right now and have for the last couple years, zero issues even in the winter.
Its all the ol'man ran in his fleet of tractors for hyd. fluid for fourty plus and still counting years... Same thing, zero issues.
Most of the bigger farms in the area also use thf 1000 on this distributors bulk oil program also.
One logging I know of uses thf 1000 in all equipment for a hyd. oil.
   / Chevron 1000 THF #9
If you're talking to me, heck no they didn't. No way I paid that. Bought Kubota SUDT2 for $100/5 gallons.
Actually, though, I think I was confused when i stated the price earlier. I got a price for Chevron All Weather HF, but I thinking the 1000 THF is different. My apologies for the misinformation.
   / Chevron 1000 THF #10
Confusion on my end also motownbrowne:eek:
Chevron all weather is a full synthetic THF IIRC, as compared to THF 1000 the syn stuff is of course more... I studied tractor hyd. fluids in depth a while back comparing name brands deere, kubota and such to not really learn much other than most of deere oils come from chevron oil. Dealers where of not much help for this, cause no other oils existed but there brands:) I do know ALOT of equipment around these parts use THF 1000 and have nary a problem
I did read somewhere to avoid 'wal-mart/farm supply store' oils, using those names and terms loosely, for bargain type hyd oils not being very consistent of actual oil additives causing issues.
2008 Sterling Bullet 4x4 HT40KX Crane Service Truck (A42742)
2008 Sterling...
2019 Wacker Neuson WL34 Wheel Loader - Low Hours, Versatile & Work-Ready (A44789)
2019 Wacker Neuson...
2015 Ford F-350 4x4 Utility Truck, VIN # 1FD8X3H67FEC72951 (A44391)
2015 Ford F-350...
Saddle Tank Bracket for JD 7820 (A40784)
Saddle Tank...
2015 VOLVO VNL64T TANDEM AXLE MID ROOF SLEEPER TRUCK (A43004)
2015 VOLVO VNL64T...
More info coming soon! (A44572)
More info coming...
