Chemtech filters
   / Chemtech filters #1
Slippy
Veteran Member
Ohio
Mahindra 6000 4wd; IH x2; NHTC40DSS; International 1086; JD 5115M
Looking for information on Chemtech filters. I have one that needs to be replaced on a diesel fuel storage tank. It has a drain on the bottom so I am guessing it is the type you drain, screw off, and then replace the internal filter. The logo on it is an indian chief if that helps.
As always, thanks.
   / Chemtech filters #2
The Chemtech filter I have on my diesel tank is like a oil filter. It also has a drain on the bottom to drain off any water. I get them at a place called Rural King. I have what is called a 3/4" filter and they also have a 1" filter. The canister is the same basic size but the threads are different.
Chris
   / Chemtech filters
So is the filter all one piece and you replace the whole thing?
   / Chemtech filters #4
It probably is one piece, most of the ones on fuel pumps are unless it has a clear plastic fuel bowl. The petcock in the bottom is to drain off accumulated water. Try TSC, they should have a filter that fit's.
   / Chemtech filters
I found them at a dealer, but they have two, one is a 2 micron and the other is a 10. Dealer said 2 micron provides better filtering but does not have drain petcock, the 10 does have drain petcock. Any thoughts or preference and how often should they be changed...time or fuel usage, or both? The fileter that is on the tank has a date of 2004, but only has about 900 gallons run through it.
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
23013 (A53421)
23013 (A53421)
2017 CATERPILLAR D11T DOZER (A52705)
2017 CATERPILLAR...
2017 HITACHI ZX350LC EXCAVATOR (A54607)
2017 HITACHI...
2015 Toro Workman MD Utility Cart (A53421)
2015 Toro Workman...
UNUSED 70PCS Grey Metal Roof Panels (A53117)
UNUSED 70PCS Grey...
