Cheep aftermarket lights
   / Cheep aftermarket lights #1
jacain
Richmond (Chesterfield), VA
Ford 2600 Ford 3910
Need some cheap aftermarket head lights for my 2600. What do you guys suggest? Thanks in advance.
Justin
   / Cheep aftermarket lights #2
You can find all kinds of lights on Ebay from $23 a pair for 55W driving lights to $30-40 for LED driving lights. Go on Ebay and type driving lights in the search line. Some have free shipping.
Thanks! I never used the term "driving lights" when searching before and that yielded more favorable results. I found some on amazon for around 11 bucks a piece that had 4 1/2 stars with over 81 reviews. I can just paint the bodies to make them look oem.
   / Cheep aftermarket lights #4
The first set of lights I posted are $23 for the pair with free shipping. For the pair you found I'd leave them chromed.
Will probably just leave them chrome like you said. They are prime eligible and I have prime so they could be here before the weekend. Thanks again.
   / Cheep aftermarket lights #6
Justin
When I upgraded my Mule (http://www.tractorbynet.com/forums/...303313-kawasaki-mule-610-upgrade-project.html) I put a two of these lights on the front of it. I bought enough of them to also put 2 on my GC2300 facing forward. I have 2 others with a flood pattern to install facing the rear. I haven't mounted them on my tractor yet, but I can tell you the ones on my Mule are extremely bright. :shocked: The fit and finish is decent, and they are all metal housings. They are also very low current draw. I ran them through a set of relays just because I'd already built my wiring harness that way, but you could run them direct from a switch. If I remember correctly, I metered them at 2.3A each.
Amazon.com: Tuff LED Lights 4 X 4" Inch Round 27watt LED Work Lamp Light 1450 Lumen, Off Road, Atv, Utv, Polaris Ranger: Automotive
I also got one of these for a backup light for the tractor, but after seeing how bright it was, I used it for the backup light on the Mule instead:
Amazon.com: TMH 20w Cree LED Work Light 60 Degree Flood Beam Spot Lamp: Automotive
Also very bright and low current draw. This one is running direct through my backup light switch. About 1.5A I think.
Now if I were putting lights on my FJ, I'd maybe go with one of the name brand LED lights or a lightbar, but it's hard to beat the price. I know for my tractor these will be fine though.
Honestly, I think most of these lower cost LED lights come off the same line as the higher priced stuff....
Good luck!
NV
2012 SULLIVAN PALATEK AIR COMPRESSOR (A52576)
2012 SULLIVAN...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
DOOSAN G25 GENERATOR (A52472)
DOOSAN G25...
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
2025 84in Dual...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
Peterbilt 377 Semi-Truck (A52748)
Peterbilt 377...
