Ken P
Folks - I've been trying to read and understand the threads on lift capacity, but I'm not sure I get it, so I thought I'd post with the specifics to see if I've got this right.
I have a Kubota B2410, with an LA352 FEL. According to the manual, I have a lift capacity at the pivot pin of 1035 lbs, and a (unspecified location) lift capacity of 770 lbs. The Breakout force at the pivot pin is 1885 lbs, and the unspecified-location breakout force is 1336 lbs.
The machine I need to lift is a Grizzly jointer, weighs in at 1056lbs as shipped (I may be able to reduce the weight by taking off some of the shipping crate, and/or some of the top of the machine, but would rather not if I don't need to). I plan to use my bolt-on pallet forks which will also be secured with a ratchet and strap around the bucket. I only need to get this thing maybe a foot off the ground, and will be carrying it about 100 feet.
So, am correct in these numbers saying that I can do this but am pretty close to capacity? Also, do I understand correctly that if I try to pick it up and it's too heavy, no harm done, the machine just won't lift? I certainly do not want to harm the tractor or loader.
Thanks, and sorry if this has been asked too many times before...
Ken
Ken
