Checking the Ph on antifreeze in a 1925
   / Checking the Ph on antifreeze in a 1925 #1
KansasKid
Kansas
New Holland 1925
How often are you suppose to check the Ph of antifreeze in a diesel tractor? Do you also put in any anticativation supplement to the antifreeze? And lastly, where do you find the litmus (sp) paper to check the Ph?
KK
   / Checking the Ph on antifreeze in a 1925 #2
I havn't seen litmus paper in a while.. but you might check medicle supply stores.. as the have ph sticks for urine ph testing.. though a simple pool tester kit may get you by?
Try a deisel rated antifreeze.. those usually have the anticavitation addatives pre-mixed.
Soundguy
   / Checking the Ph on antifreeze in a 1925 #3
</font><font color="blue" class="small">( check the Ph of antifreeze )</font> /forums/images/graemlins/confused.gif
Never heard of such a thing.
Why would you want to know your antifreez's PH level ?
The only thing I have ever checked my antifreeze (radiator fluid) for was it's temperature limit ? ie. good for x degrees below O
If this is the test result your looking for?
You can buy an inexpensive testor from NAPA or even Walmart for this.
   / Checking the Ph on antifreeze in a 1925 #4
I think what you really want to check is your DCA level, thats the anti-cavitation additive that diesels need. Find yourself an International or other heavy truck dealer and talk to their parts department, or even your NH dealer. If the dealer doesn't have a clue, the "big" truck dealer had better. /forums/images/graemlins/smile.gif
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
2016 FREIGHTLINER CASCADIA DAY CAB (A52141)
2016 FREIGHTLINER...
2012 John Deere 7280R MFWD Tractor (A52748)
2012 John Deere...
Deere 317G (A50120)
Deere 317G (A50120)
Jacobsen Turfcat T628D Front Cut Mower (RUNS) (A50774)
Jacobsen Turfcat...
