Checking pressures on Kubota L35
   / Checking pressures on Kubota L35 #1
pc3199
Equality, Alabama
Case International MXM135
Hello! I was wondering if someone could tell me how to check the pressure on a Kubota L35. The GST pressure, The GST Relief Valve Setting Pressure, The GST pilot pressure, and The GST Clutch Pack Pressure. I don't know where to check these and I don't (as of yet) have a service manual. The transmission is not pulling sufficient enough to preform. Thank you for your help!
   / Checking pressures on Kubota L35 #2
:welcome:
To the forum from Northwest Alabama. I used to drive through there a lot when going from Lineville, where my wife is from, to Montgomery on AL9 back when I was in the Air Force. Can't help with your problem, sorry.
   / Checking pressures on Kubota L35 #3
Welcome aboard, you'll likely get a quicker response on the hydraulics forum.
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A50046)
2018 FREIGHTLINER...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A51039)
John Deere 6105E...
S/A Utility Trailer (A49461)
S/A Utility...
2015 CAT 573c Fellerbuncher Cutter (A48836)
2015 CAT 573c...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
2019 GENIE Z-45/25XC V2 TELESCOPIC MANLIFT (A51242)
2019 GENIE...
