checking hydraulic fluid level on L245DT
   / checking hydraulic fluid level on L245DT #1
fgable
PA
Kubota L245DT
My new/old L245DT tractor did not come with an owners manual (one on order). Do I check the hydraulic fluid by just looking down the fill cap? I see no obvious dipstick or sight glass. Thanks, look forward to participating on this board
   / checking hydraulic fluid level on L245DT #2
There isn't any dipstick or looking glass that I remember. If you just got it, it might not be a bad idea just to change it. Any dealer can tell you what the capacity should be. You can't tell from just looking into the filler cap because even when it is full it doesn't come up to eye level.
   / checking hydraulic fluid level on L245DT #3
The L245DT has a bolt on the left side of the transmission (near your left foot while sitting on it) that is used to decide it is full. The instructions say you should fill until it comes out this hole a little bit. Just like filling a differential on a rear wheel drive car. Be careful loosening this bolt I had trouble getting mine out and ended up rounding the head so much that I had to weld a nut on it. Good luck
   / checking hydraulic fluid level on L245DT #4
Tom Aiken - Off the subject but your name sounds real familiar to me. Do you hail from up here in N.E. Pa?
Thanks, found it, opened it and out came fluid. I think the seller intentionally over filled it.
2017 Freightliner M2 106 24FT Box Truck (A50323)
2017 Freightliner...
Unused Rhino ER10 Hay Rake (A50515)
Unused Rhino ER10...
2011 Cadillac DTS Sedan (A50324)
2011 Cadillac DTS...
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
2019 TOYOTA 8FGCU25 PROPANE FORKLIFT (A51222)
2019 TOYOTA...
2005 Ford F-550 Bucket Truck, VIN # 1FDAF56P45EB88239 (A48836)
2005 Ford F-550...
