Checking Fluid Levels
   / Checking Fluid Levels #1
bulldog7
Wilsonville, Al
Yanmar 1610D
Do you check the transmission, front axle fluid levels with the stick screwed
in our out? I own a 1610D and do not have any manuals to find this out. Sorry
for the double post, I didn't mean to do that.
   / Checking Fluid Levels #2
There was a post about a month ago on the same question, and someone had a manual that said to check fluids with the dip sticks unscrewed. Don't know how accurate that is, but hope this helps.
   / Checking Fluid Levels #3
Yanmar-USA's manuals are pretty ambiguous. For threaded dipsticks like the crankcase or front axle it is pretty clear to take a reading with the dipstick unthreaded and resting in the opening.
But the transmission dipstick on my YM186D (US version YM1500D) is a rod that goes through a tapered rubber plug that is simply pushed straight into the transmission. Regarding reading this dipstick I have found the following.
YM186(D)Service Manual, Dealer's preDelivery checkout:
"Confirm that the transmission is up to the required level by using the dipstick."
YM186(D)Service Manual, After-Sale inspection:
"With the trator on level ground, loosen the dipstick and see if the oil level is in the safe range. If not, add enough oil to bring it up to the top of the crosshatching."
[Mine just has a single horizontal line maybe a quarter inch from the end. I assume that line is 'the top of the crosshatching'.]
YM186(D)Operation Manual, Pre-Starting Inspection:
YM186(D)Operation Manual, Service:
"Remove dipstick and wipe it clean. Insert dipstick to the end. Oil should be between full mark (upper) and end of dipstick. If low, add oil as specified on page 47."
[my emphasis.]
Ok, there I think we have the source for all the confusion, and finally a definitive answer in the line
At least if we are talking about the type of dipstick that passes through a rubber plug, and is shoved, rather than threaded, into place.
I still think they intend all the threaded dipsticks to be checked resting at the top of the threads.
Off topic - I also noted that they say to check the engine oil after 10 minutes resting, not immediately on shutdown.
Clear as mud? :D
   / Checking Fluid Levels #4
The manual on page 40 states to remove the transmission dipstick and wipe clean and RE-INSERT, oil should be at the top of the flat part of the stick or below. The front axle states to remove plug on top of the axle, wipe dipstick clean and re-insert but DO NOT THREAD BACK IN. You might want to get a manual from one of the dealers here at this site. I got mine and my tractor from RCO in Austin TX. Lots of good info in there.
Mark 1610d
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
(4) 55 GALLON POLY DRUMS (A51248)
(4) 55 GALLON POLY...
2021 JOHN DEERE 7R230 LOT NUMBER 204 (A53084)
2021 JOHN DEERE...
2020 JOHN DEERE 8R 250 LOT IDENTIFIER 172 (A53084)
2020 JOHN DEERE 8R...
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
