ClemBert
When I check the air pressure with a normal pressure gauge water always comes out. The tires are rotated in the position where the valve stems are at their highest point. Do I need a special device to check air pressure in a water filled tire? Or is a special device only needed when adding water to a tire? The max pressure on the label is 26 PSI and I assume for water filled tired that the maximum should be put in. Is that true?
