Check Your Snow Blower(s)
   / Check Your Snow Blower(s) #1
timm9
Sierras, CA
Toolcat(s) 5600B-Turbo(s)
I thought I would take a moment and give those of you running Snow Blowers a quick heads up and hopefully you can prevent a major break down during a storm.
In preparation for the upcoming season I decided to tear down my Blowers a little farther than I typically do including the Auger and Auger Motor assembly. Upon removing the Auger, I discovered that the 9/16 grade eight bolt which secures the end of the drive block as it engages the Auger was missing. After closer examination, I found the bolt was actually broken off inside the Auger Motor shaft. Fortunately, I was able to drill and extract the broken bolt from the Motor Shaft without having to replace the Auger Motor. The Service Manual indicates the bolt should be torqued to 28 lbs. The only thing I can figure is that this grade eight bolt broke due to being over torqued.
Tim
   / Check Your Snow Blower(s) #2
Check the electrical connector as well. The 7 pins in mine looked something less than clean. Last year when I was prepping my blower I noticed that one of the six fan bolts was gone and the remainder were all loose. It never ends...
I know exactly what you mean...
We have started checking the fan bolts in between storms when we grease. Also, If you have not changed out your bolts on the shute guides to nylocks you might seriously consider it as well.
Tim
2018 HINO 268 26FT BOX TRUCK (A51222)
2018 HINO 268 26FT...
2004 STERLING LT9500 SERIES MIXER TRUCK (A50854)
2004 STERLING...
2014 RAM 5500 FLATBED TRUCK (A51222)
2014 RAM 5500...
2015 Ford Escape 4x4 SUV (A50324)
2015 Ford Escape...
2008 24ft. Haulmark Edge T/A Enclosed Trailer (A49461)
2008 24ft...
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A51039)
NEW 2022 Load...
