Check your lug bolts!
   / Check your lug bolts! #1
LincTex
Elm Mott, TX
Farmall 404
My first "failure", at 144 hours: lifted the front end with the loader to just routinely check spindle bearings,
and noticed the RH side lug bolts were all loose.
Some of the bolts were already about 1/4 inch threaded out.
Of course, no one has any 14mm x 1.5mm grade 10.9 bolts locally.
I'll have to order some. (Some Chevy oil drain plugs come in this size, though)
Maybe a thread die will clean these up.....
Or make some from late model F-250 wheel studs
Side note: the tie rod "ball joints" that connect the steering cylinder (to the actual tie rods themselves) are REALLY sloppy.
Far more sloppy than a tractor with 144 hours should have.
   / Check your lug bolts! #2
Use blue LockTite on lug nuts and they won't loosen up again. They are still easy enough to get off later, but won't work themselves off like yours did.
   / Check your lug bolts! #3
I checked the lug nuts on my Workmaster when I completed the 50 hour service and all were tight. I noticed witness marks on the lug bolts and saw no movement. Don't know if Loctite was used but all were tight including FEL frame bolts.
Sounds like you got some GOOD dealer prep, as it should be. No "witness" marks anywhere on mine. The LH side are all tight.
2001 Subaru Outback AWD SUV (A51694)
2001 Subaru...
2015 TOP HAT TRAILER 20 FOOT UTILITY TRAILER (A53843)
2015 TOP HAT...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A51692)
2016 Chevrolet...
Trojan 8T-50 46in Hydraulic Thumb Excavator Attachment (A51691)
Trojan 8T-50 46in...
Truck Wheel Fenders (A51692)
Truck Wheel...
2016 Mobility Ventures MV-1 Van (A51694)
2016 Mobility...
