check your antifreeze
   / check your antifreeze #1
inthe country
Rome, Ohio
Kioti CK3510
2016 Kioti CK3510 antifreeze change. I emptied the radiator with the plug on the side, emptied the reservoir bottle and disconnected the lower radiator hose. I then filled with fresh water and ran to warm up, then I drained it as before. I mixed Shell Rotella 50/50 with fresh water and filled the radiator.
I've used the tractor and all seemed fine, but when I checked the antifreeze again its only good for -7 not the -37 you should get with a 50/50 mix. Apparently there is enough water left in the engine when you drain it to seriously affect the freeze point of the antifreeze. I don't have a service manual does it have further instructions on draining the radiator? Is there something I missed? I know I will not trust the owner's manual anymore.
I've drained the radiator again and filled with 50/50 mix and tested to be sure it's -37. I'm waiting for it to cool down so I can test again. I will probably have to buy more Rotella and use it straight to get the right freeze point.
   / check your antifreeze #2
Make sure you had the straight concentrate and not the 50/50 pre-mix. If you mixed water with what was already 50% water, then you got a 75/25 water to glycol mix which is why the freeze point isn't that low. Buy 50/50 or by concentrate and dilute it yourself.
   / check your antifreeze #3
Usually there's also an engine block drain. Look along either side for a plug head or petcock.
When I changed the antifreeze for the first time in the Ford 850 after buying it years ago, I could tell I wasn't getting a full drain. Then I found the petcock on the side of the block and was shocked to see soupy 'mud' ooze out. I did several thorough flushes and it finally was draining good and clear. It's remained clean on each change after that too. Apparently that block drain wasn't used for years, if ever, in it's first 45 years.
   / check your antifreeze #4
Yup getting to be that time of year again...set mine for -25F.
I started with pure antifreeze and mixed it 50/50. It was not already 50/50. I just refilled with the extra fluid I had left over it tested at -37, after warming it up so it would mix and letting it cool down it tested just below -20. I can only conclude there is a good sized part of the block that does not drain. I see several freeze plugs but no drain plugs on the engine block. The owner's manual does not address any drain other than the one on the radiator. That book is truly sad. I would email Kioti, but I've never received a reply for any email I've sent to Kioti.
If you changed your antifreeze make sure to check it again. At -7 my block would have been toast. Our record low is -34.
   / check your antifreeze #6
When I drain and flush mine I use the air hose to blow out the engine all I can, that when I start filling I add straight 100% coolant to at least 60% of my radiators capacity, then I continue to fill with a 60-40 mix I would rather be a bit over strength than any thing under.
   / check your antifreeze #7
The fresh-water flush will help clean out any crud but it always leaves fresh water trapped in the engine. So compute and add the required amount of 100% anti-freeze (based on coolant capacity) to get your 50-50 mix and then top up with water. Recheck coolant level (after running the engine at temp and letting it cool) in case trapped air prevented a complete fill.
   / check your antifreeze #8
My tractor cooling system is two and a half gallons. After draining and flushing - I pour one gallon and one quart of unmixed antifreeze into the radiator. I then add distilled water to complete the fill up. This way I am guaranteed to get protection down to around -40F.
Also the way I do this - makes absolutely no difference how much water might be trapped wherever - I got the 50% quantity of undiluted antifreeze into the cooling system. So the undiluted antifreeze can mix with the trapped water and the distilled water I add and the result will always be a 50/50 mix or better.
You add 50/50 premix - the amount of trapped water will make a difference.
   / check your antifreeze #9
I have several cases over the past 15 years where I would purchase the concentrated prestone antifreeze, dump half into another jug, and then fill both back full with water, and shake the jug, and then test with the freeze gauge, and it would also register -10 or so with more than one gauge. Asked a few people that should know and was told the concentrate is a 85/15 mix not full concentrate. I mostly just use the 50/50 anymore,
   / check your antifreeze #10
I use the drain on the bottom of the rad. When the juice stops flowing, close the drain and fill the rad with concentrate right to the top. Run the engine for a bit to warm up, shut down and top off the tank and rad with water. I get a constant -55 every time. I have done it this way for years. I haven't cracked a block yet, touch wood.
2020 Caterpillar 420F2 4x4 Extendahoe Loader Backhoe (A50322)
2020 Caterpillar...
Toro Workman Utility Cart (A51694)
Toro Workman...
Loader Bucket (A50322)
KJ 7'x20' Metal Gate (Deer) (A50121)
KJ 7'x20' Metal...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
