"Check valve" for pond overflow
   / "Check valve" for pond overflow #1
Rusty
Hampton Township, Bay County, Michigan
Kubota B7500HSD-R
\"Check valve\" for pond overflow
I'm looking for a source or design for a low cost "check valve" for the discharge end of the flexible field tile that lets my pond overflow into a shallow drainage ditch. I think the field tile is 6" diameter, but I need to check that. The drainage ditch is empty during dry weather conditions, but fills during snow melt and rain events. The field tile exits to the elevation of the bottom of the ditch and backfills the pond when the ditch fills. The "check valve" would need to open under low (less than 1') head differential. Thanks, for any suggestions! /forums/images/graemlins/smile.gif
   / "Check valve" for pond overflow #3
Re: \"Check valve\" for pond overflow
Try an inner tube and a hose clamp. Inner tube would flatten on attempted back flow. You might need some cross bars on the pipe to prevent the tube from reversing. Just a thought, haven't tried it myself, 100% of what you paid for this advise refunded if it doesn't work.
   / "Check valve" for pond overflow #4
Once you make your 1st purchase from Agri Drain from that point forward you'll get their catalogs on a regular basis. They are very quick to ship and carry quality products for pond management.
midlf & PineRidge: Thanks for the responses! I ordered two Agri Drain FG06 6" Hinged Flap Gates today. One is for the pond and one is for another drain that I have to the same shallow ditch. The Customer Service Representative confirmed the application for me. Thanks, again! /forums/images/graemlins/laugh.gif Rusty
2008 Ford F-550 11ft Flatbed Truck (A52377)
2008 Ford F-550...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
2019 Genie GS-3232 32ft Electric Scissor Lift (A53421)
2019 Genie GS-3232...
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
KUBOTA M5660 SU TRACTOR (A52706)
KUBOTA M5660 SU...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
