Check the Bolts
   / Check the Bolts #1
Jag
Central Arkansas
Kubota /L2650/ LA450/B4690 -- John Deere 450 Dozer
For those who missed it because it was under a Kubota forum, be sure to check those important bolts.... I started to do the 500 hour PM and went to check all the bolts on the front end loader and ROPS and backhoe mounting brackets. Few of the bolts on the ROPS were to specifications, most were less than half... The 16 or so bolts on the FEL bracket to the tractor, one was loose, about 6 would easily turn with a small wrench. Everything on the backhoe bracket was to specifications because the dealer had worked on it less than 20 hours ago.... DO NOT forget to check those BOLTS
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
Bush Hog R0-720 Pull-Behind Ripper Tractor Attachment (A51691)
Bush Hog R0-720...
2009 BOBCAT 442E (A52472)
2009 BOBCAT 442E...
2005 TRANSCRAFT 48 X 102 FLATBED (A52472)
2005 TRANSCRAFT 48...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2022 JOHN DEERE 5075E LOT NUMBER 30 (A53084)
2022 JOHN DEERE...
