Check out my new LED lights!
   / Check out my new LED lights! #1
Dexterous
Grove City, PA
2019 Kubota B2650
I just got my B2650 on Saturday and I have already done a few customization's. I started by installing the high output alternator as mentioned in another thread. I then moved on to installing six LED cube lights, two on the ROPS front facing, two on the ROPS rear facing and two on the backhoe.
Here are a few pict. I am especially pleased with how the backhoe lights turned out.
Here are a few close-up shots of my hoe light bracket. This was made out of a piece of aluminum bar.
Here's the quick connect wire going to the backhoe:
Last but not least, I installed all the relays (one per two light set) in a waterproof project box which I then mounted between the frame rails under the battery. Hopefully this spot is protected from the elements and I dont have any issues.
I just went out and tried the new lights and they work great.
Driving forward:
From the side (front lights off to cut glare):
Backhoe Operation - straight on:
Backhoe Operation - bucket to the side:
   / Check out my new LED lights! #5
Very nice install. I have had LED lights on my last 2 machines, and the night time visibility is phenomenal. I used to hate plowing at night with the OEM incandescent lights. Now it's practically just like daylight within 50 feet of the tractor.
   / Check out my new LED lights! #6
Nicely done :thumbsup: LRD does make BIG different compare to yester years lighting.
2007 CATERPILLAR 303.5C CR EXCAVATOR (A51242)
2007 CATERPILLAR...
2017 John Deere 30G Mini Excavator (A50322)
2017 John Deere...
Glenco Disk Chisel (A50515)
Glenco Disk Chisel...
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
2016 Kenworth T800 Tandem Axle Road Tractor (A47384)
2016 Kenworth T800...
Wolverine Mini Skid Steer Combination Bucket (A50514)
Wolverine Mini...
