Chains Check chains on bus hog
   / Check chains on bus hog #1
oldgeezer
Western Arkansas
2007 Kubota GL3240
Check chains on bush hog
1st off, MERRY CHRISTMAS EVERYBODY ! ! !
Now: I have always used check chains on previous tractors & bush hogs so I can let the hog float at a certain height & not gouge the ground in the front. I now have a Kubota Grand L3240 tractor & a Woods Brush Bull BB60 hog. There is a check chain assembly available from Woods which could just as easily be cobbled up in the shop. However, the rear pto shaft guard on the tractor is in the way of the chains on their way from the hog up to the top link bracket of the tractor. Has anyone figured out a good way to use check chains on this combination?? Any ideas??
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2020 CATERPILLAR 242D3 WHEELED SKID STEER (A51242)
2020 CATERPILLAR...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
2004 TAKEUCHI TB175 EXCAVATOR (A51242)
2004 TAKEUCHI...
Danuser 3 pt Post Hole Digger (A50515)
Danuser 3 pt Post...
2002 International 4400 SBA 4x2 Flatbed Truck (A50323)
2002 International...
