cheap watering
   / cheap watering #1
pickstock
i have a little problem, i'm from australia further than most people on this forum and well we have a water issue. it doesn't rain that often.
this year i put in about a hectare of barley by hand just for our stud sheep to graze but this year i want to go good pasture but for that i need to water it ay suggestions to make soemthing for he tractor??
btw its an old zetor with 3 point linkage and not to much horsepower but does have an aircompressor mounted to it
thanks in advance
spike
   / cheap watering #2
PTO powered pump?
Do you have a well? Creek? Lake? Neighbor that chews tobacco?
jb
   / cheap watering #3
That's what I'm thinking a PTO pump. And for a delievery system maybe a "rapid rain". Basically it's a sprinkler mounted on a long hose and winds itself up as it's irrigating.
   / cheap watering #4
PTO powered pump?
jb
I'll second that, PTO Pump and a "Water Buffalo" (= large capacity liquid tank trailer) if distance is to great to run hoses/PVC.
as for "Cheap Water", a Creek or Lake or Pond could be a good source to fill the tank. Filter the suction line.
Suggest a high flow rate "GPM or Liter Per Minute Pump" so the task can be more quickly done. High flow rate spray nozzles for delivery will help to. Watering right at dark will help too.
High Volume / Self Powered pumps are also available at very reasonable prices.
For ideas Try Sparex then navigate to 'Accessories > Workshop > Fuel & Fluid Delivery & Storage > Pumps - PTO Driven
Good Luck
Rhett
   / cheap watering
well the water is probably the problem but not one that can be easily rectified
i'm planning to build a large hay shed/barn to colect water off of then into rain tanks
thanks for the advice i'll be buliding the pump and what not soon
   / cheap watering #6
What is the size of the area that you want to irrigate. Due to rapid evapouration I would suggest look into drip irrigation. Build a header tank that will supply enough pressure to allow the water to permiate the soil.
Drip Irrigation System Design Guidelines
2024 Greatbear 72in Vibratory Roller Skid Steer Attachment (A51691)
2024 Greatbear...
Kubota RTV500 (A47384)
(3) STEEL CARTS W/ WHEELS (A51248)
(3) STEEL CARTS W/...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2003 Ferris IS1000 52in Zero Turn Mower (A51694)
2003 Ferris IS1000...
2017 Nissan Altima Sedan (A51694)
2017 Nissan Altima...
