Cheap, LIGHTWEIGHT push mower
/ Cheap, LIGHTWEIGHT push mower #1
fivestring
Veteran Member
South Central NC, USofA
Iseki TU1700f
I need one.
It is for trim work and the ditchbank (30-50 degree slope).
Thus, the light weight need. I know about oil starvation and all.
I do not want self-propelled; too heavy.
I DO NOT WANT ANYTHING BY MTD.
Is Murray still made by Murray?
Does Snapper make any?
Thanks, Gary
/ Cheap, LIGHTWEIGHT push mower #2
Are the cheap ones at Walmart MTD or Murray? I bought one for about $89 a few years ago and used it like a brush hog on my place in town. Not much grass, just rocks and weeds. It would still be working if I hadn't decided to swap the motor to the body of the next one I bought for about $120 and then bent the shaft of by running it over a stump. Not much to those things except the motor, so what difference does it make if it's MTD or Murray?
Chuck
/ Cheap, LIGHTWEIGHT push mower #3
CHEAP?! I DO NOT WANT ANYTHING BY MTD. /forums/images/graemlins/shocked.gif
<font color="red"> GOOD LUCK!!! </font> /forums/images/graemlins/tongue.gif
/ Cheap, LIGHTWEIGHT push mower #4
Buy used!
Find a nice clean mower from the 1970's with an aluminum deck with a good strong engine.
Around here, people have them set out in their front yard for sale all the time for anywhere between $20 to $50.
It's more lightweight than anything you can buy today and easy to maneuver.
/ Cheap, LIGHTWEIGHT push mower #5
Gary,
I've got the perfect mower for you! Lightweight, Not self-propelled, No worries with oil starvation. It costs $69.99.
Great States Model 1204
OMG!!!!!
That brings back nightmares!
My dad made me cut grass with one of those when I was young.
It is environmentally friendly, tho!
I can't use it, though. It says it's not for tall grass.
Since the state makes me cut the ditchbank. I let it get REAL tall before I cut it. /forums/images/graemlins/grin.gif
That's the kind of cheap I want. /forums/images/graemlins/grin.gif
Maybe someone will answer if it's MTD.
Real bad luck with MTD products. 0 for 3. /forums/images/graemlins/frown.gif
I've only had one Murray. It was still in good shape when I gave it to my step-daughter.
"CHEAP?! I DO NOT WANT ANYTHING BY MTD.
GOOD LUCK!!!"
I know. I know.
SWMBO won't let me have goats.
/ Cheap, LIGHTWEIGHT push mower #9
Gary:
did you say real steep slopes? And the grass was long!
Attachment.
Egon
/ Cheap, LIGHTWEIGHT push mower #10
Fivestring:
Years ago, when I lived in Ohio, I had a really neat lawnmower. It was called a Flymow. Basically, it had no wheels, a 2 stroke engine so it needed no oil other than the gas-oil mix.
We had a ditch bank that was at least 30 degrees. The flymow had a set of little hooks on the handle that you tied a rope to. You stood at the top of the bank and reeled the mower via the rope up and down the ditch bank.
It worked on the principle of a hover craft. It mulched so there was no clippings and it handled heavy grass and weeds no problem. I gave it away years ago. I wish I had it now. I have some ditchbanks and I have to burn them each spring.
Maybe you could find one on e-bay or somewhere. I know they were patented, but I haven't seen one in years. If I remember correctly, it had a Lawnboy engine on it. A really neat, innovative mower.
/ Cheap, LIGHTWEIGHT push mower #11
Fivestring:
I went a searched the web. I spelled Flymow wrong. It's Flymo.
I did a Google search for flymo and came up with their European website. Problem is, they are no longer or not presently sold in the USA. Seems as though Electrolux group owns them. Again, I wish I still had mine. You can't beat them for mowing steep inclined slopes. I have a friend in the UK. Maybe he could get me one and send it to me. /forums/images/graemlins/laugh.gif
/ Cheap, LIGHTWEIGHT push mower #12
Fivestring,
I suspect that both mowers I bought at WallyWorld were MTD's. If I decide to wade through the grass that has grown several inches since last Saturday when I cut it, braving the crappy drizzle that's coming down, I'll go to my shed and check. Both were cheap 21" mowers, but last year when it was decided that I couldn't get a riding mower, I splurged on the next model from the bottom. It had high wheels in the back and since I have some hills and bumps to deal with I thought that might make maneuvering easier. I didn't really get a chance to find out because I almost immediately hit a stump hidden in tall grass and bent the shaft. In my next life, I plan to learn about small gas engines, but in this life I was at least able to swap the engine from the old mower to the new body. The old mower was still working OK, but in using it as a brush hog, I had managed to catch the gas tank on so many bushes and such that the main bolt holding it on had fallen off. Not having one of that size in my collection, I basically tied the tank-carb piece to the motor with wire. So, when I switched the motor to the new body, I swapped the tank-carb stuff from the old to the new. The only problem then was that the shaft length was different, so that my Frankenstein mower didn't cut as well as it might. Then one of the guys at work gave me an old Companion (Sears) push mower because he had gotten a new self-propelled. After emptying the water from the gas tank and cleaning it up a bit, it works fine. Now if it doesn't just rust completely to pieces, it should serve to do the trim work I can't do with the riding mower my CFO promises me I can get this year. I have a long ditch to do, too, and I suspect I will be unable to overcome the pucker factor to do that with the riding mower.
The idea of a used mower is probably good, if you can deal with the mysteries of the engines. To me they're black boxes with very few pieces I can swap out in case of problems.
Chuck
/ Cheap, LIGHTWEIGHT push mower #14
The old 2-stroke lawnboys were great until you loaned them out and someone failed to mix oil with the gas. I worked at a shop in high school that sold and repaired them. We had a pile of them with burned up (loaned out) engines. My boss sold me one for $25 bucks. I put a new engine short block on it (dealer cost $90) and used it for about 15 years.
Lawnboys 2 cycle mowers selling point was "33% lighter than a Briggs"
/ Cheap, LIGHTWEIGHT push mower #15
</font><font color="blue" class="small">( The old 2-stroke lawnboys were great )</font>
Definitely my all time favorite walk behind mowers. I bought a used one; supposedly one or two years old in 1973 or 1974. It was still a fine mower when I retired, sold the house, took off in an RV, and gave it to a son-in-law in 1989. When one of our daughters bought her house a couple of years ago, she said she negotiated with the prior owner to throw in a year old Lawnboy mower, and I told her you can't better than that. Well . . ., it ain't bad, but I didn't know they made them now with a 4 stroke Tecumseh engine. /forums/images/graemlins/frown.gif
/ Cheap, LIGHTWEIGHT push mower #16
I always thought MTD = Made To Die
/ Cheap, LIGHTWEIGHT push mower #17
I believe that it is one of the founders last initial "<font color="blue">M</font>" <font color="blue"> T</font>ool and <font color="blue">D</font>ie = <font color="blue">MTD /forums/images/graemlins/grin.gif /forums/images/graemlins/wink.gif!</font>
/ Cheap, LIGHTWEIGHT push mower #18
Bird:
Tecumseh engines.....well, they do make really good refrigeration compressors, but their engines leave something to be desired. /forums/images/graemlins/frown.gif Their main plant is about 10 miles from here, in Tecumseh, Michigan, no doubt. /forums/images/graemlins/grin.gif
/ Cheap, LIGHTWEIGHT push mower #19
</font><font color="blue" class="small">( 5030:
Tecumseh engines.....but their engines leave something to be desired. /forums/images/graemlins/frown.gif )</font>
My snowblower has a Tecumseh 7HP. I've had it for 7 years so far and still starts right up. If I had the choice though, I'd go with B&S.
When I bought it, your statement is the response I got from most people that I asked about "How good are they".
I took a chance and so far, so good. Just my thoughts.
/ Cheap, LIGHTWEIGHT push mower #20
Gerard:
My snowblower has a 50 horse Kubota motor.
You are lucky. I had a Tecumseh engine on an Ariens rototiller that I sold. It burned oil, ran rough and ate one of the screws that held the choke plate on it's shaft. Made a real bad noise as the screw hit the cylinder head. I took the head off, ground the screw out of the head of the piston (it embedded itself in the piston crown), ground off the divots and put it back together. I subsequently sold it.
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 International DuraStar 4300 24ft. Box Truck (A59230)
2019 International...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2017 Genie GTH-5519 (A53317)
2017 Genie...
