Cheap cylinder: What could I do with it?
/ Cheap cylinder: What could I do with it? #1
bcp
Super Star Member
SW WA
Kubota BX2360
I have an opportunity to buy a new 3.5x8 hydraulic cylinder for $30+. Seems too good to pass up, but I don't know what I would do with it.
What would you do?
Bruce
/ Cheap cylinder: What could I do with it? #2
I would get it for $30 and figure that out later. Heck for $30 I would just experiment with it and see what I could come up with.
/ Cheap cylinder: What could I do with it? #3
Well the bore is fairly big but the stroke is about right for a back blade angle adjustment cylinder or a top n tilt.
/ Cheap cylinder: What could I do with it? #4
What would you do?
Bruce
The bore is a bit of overkill...but it should work for a tree shear...
/ Cheap cylinder: What could I do with it? #5
A deal aint a deal if you dont have a use for it.
/ Cheap cylinder: What could I do with it? #7
I run 3.5x8 cylinders on the blade and landscape rake only because that is what I found at bargain price. I will say that the larger bore cylinders do slow down the motion to a reasonable speed without using restrictors. The same could be accomplished, however, with a smaller bore but longer stroke.
/ Cheap cylinder: What could I do with it? #8
I have thought of making a brush puller that has a foot that sets on the ground and uses a hyd. cylinder to pull a chain straight up so that my little tractor could pull some small tree that are to big for it to pull as it is. Ed
/ Cheap cylinder: What could I do with it? #9
I think 3.5 is about perfect for a hydraulic angle blade. Dont want to go too small on the bore or you will blow hoses. And the slow angling would be more of a benefit.
Other ideas...
Grapple lid cylinder
Log lifter cylinder
TNT
Shop press
/ Cheap cylinder: What could I do with it? #10
The stroke is a bit short, but you could put two grab hooks on the ends, and use it for a portable "come along" that could pull you out of the mud if you ever get stuck. You need a chain, and then another short chain with grab hooks to take up the slack you would gain with this cylinder. Cheaper than a tow truck. Easier than cranking on a come a long.
/ Cheap cylinder: What could I do with it? #11
LOL, I obtained 2 like that some 20 years ago (2 for $25). A deal that could not be passed up you'll all agree.
They are still on my shelf waiting for a project.
/ Cheap cylinder: What could I do with it? #12
What would you do?
Bruce
If its really brand-new and unused, I'd sell it. Depending on tube and ends (welded, pin eye or clevis), they bring $70 - $140 on eBay. Start building up a PayPal surplus using eBay and then buy the things you really need. That fits in a USPS box and is under 70 lbs. Heck, maybe even a bubble mailer. Don't laugh. This is the new economy. Screw the IRS.
2002 Dodge Ram Crew Cab Pickup Truck (A61573)
2002 Dodge Ram...
2019 ISUZU NPR 4X2 S/A 18FT FLATBED (A59912)
2019 ISUZU NPR 4X2...
2012 GMC Sierra 1500 SLE 4x4 Crew Cab Pickup Truck (A61573)
2012 GMC Sierra...
Misc. Items (A64119)
(50) UNUSED 3'x8' CORRUGATED METAL SHEETS (A64281)
(50) UNUSED 3'x8'...
2023 SANY SY225C EXCAVATOR (A63276)
2023 SANY SY225C...
