Cheap Aftermarket John Starter
/ Cheap Aftermarket John Starter #1
Gale Hawkins
Super Star Member
Murray, KY
1948 Allis Chambers Model B 1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel / 1980 3600 Diesel
[ame=http://www.amazon.com/Starter-Tractor-1965-1992-Engines-1107577/dp/tech-data/B0062O1GS8]Amazon.com: New Starter John Deere Tractor 1965-1992 310 350 401 450 480 510 Diesel Engines 1107577, 1107599, 1107863, 1107871: Automotive[/ame]
After it setting for 18 months in a box I finally planned to install it today after all the flooding yesterday. After getting the dirt dabblers nest off of it the son and I got it installed.
I did not test it before installing and afterwards it would do NOTHING.
That is kind of a sick feeling know there is not returning it now. On double checking it was wired just like the OEM starter and the 12 volts was hot at the starter. On applying 12v to the small empty post it clicked so I swapped out the mounting location of the very small wire and it fired up.
After about six restarts all seems well. The old gear was messed up some and the flywheel ring just a bit chewed on. If this new on will last for another 29 years I will be happy and will replace it on my 90th birthday. :D
/ Cheap Aftermarket John Starter #2
Gale Hawkins said:
Video Link: http://www.amazon.com/Starter-Tractor-1965-1992-Engines-1107577/dp/tech-data/B0062O1GS8
When you are 90 I would suggest not buying it a year and a half early. Just in case you kick off before the starter does.
Thanks for a laugh. I was waiting for the movie John Carter to start and cracked up.:D
It died in the fall of 2010 right before I wanted to use it to help a crew build a large version of the two story storage building that you see at Lowes.
After ordering it I took the old one apart to find the engaging parts to be all rusty and falling apart. After many tries I got it to stick together until I could get it bolted back together and it would start sometimes and other times just spin up the electric starting motor. The new one arrived mid project so I did not install it until today.
2006 CHEVROLET 2500 SERVICE TRUCK (A63291)
2006 CHEVROLET...
AgCo Console 1 Monitor (A63117)
AgCo Console 1...
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
