mohinder100
- Joined
- May 5, 2011
- Messages
- 12
- Tractor
- CK 30 HST
I have Kioti CK 30 HST 2007 tractor with approx. 160 hours. For last several months, the charging system warning light comes on and stays on. It goes off when the tractor is on for some time but it comes back on sporadically. The tractor cranks up fine, even with repeated cranking, so it seems the battery is fine.
Lately, my tractor frequently cranks but does not start for several cranks. If I take the key out, wait for a minute or so and then try, all of a sudden it starts on first crank turn. There is no regularity to when it starts right up or just keeps cranking. Battery is strong enough to keep cranking the engine.
I am wondering if the two problems are related? Never had starting problem. The charging light problem has been there for months. I was just ignoring it because i could not pin point the cause but obliviously the system was charging the system enough to keep the battery charged.
I am looking for advise on what I should do. Thanks for your help.
