Charging Issue
/ Charging Issue #1
Shadow99
Southwick,MA
Pasquali 993 w/FEL, Economy2414 w/FEL
I've got a Pasquali 993 with the 30hp Ruggerini 2cyl, it uses old-school alternator with separate voltage regulator. Noticed after installing some aux. lights, that it was not charging the battery. Put load-meter on it, & at 2500rpm had 13.3vdc & 4.3 amp-output, at max rpm of 3000 had only 13.7vdc @ 5 amps:mad:. Saw in an old PDF manual that it should be 14.8vdc & 18 amp output @ 3000rpm. But the manual is very-vague as to whether to go after the voltage-regulator or the stator-windings/de-magged rotor.:confused:
I ohmmed out the 3 wires coming out the stator (2 yellows & red), got continuty between 1 yellow & red. Manual shows 2 yellows tied together when checking for open-circuit across the red, but that doesn't make sense to me. Their is no continuty between the 2 yellows themselves, & nothing for all 3 to ground. Figured I might try & use the voltage regulator off my '64 Springfield GT50, it used a very simular set up (combo starter/generator & voltage regulator @ 15amps). Gotta be cheaper than any virtually-extinct OEM part.
Thanks Guys!
Shadow
/ Charging Issue #2
It's not nearly as common for those "dynamos" to fail, as it is for the diodes and regulator. From what you are saying it sounds like everything but the windings are external to the unit itself, so I would focus on checking out the diodes first. There are typically 3-8 of them, and it sounds like the majority of them are blown out. A simple ohmmeter check of them should show continuity in one direction and high resistance in the other direction.
Good luck!
/ Charging Issue #3
Is the stator under the flywheel,like a lawnmower? Or does it have an automotive type alternator? If it is under the flywheel,then unplug it,start it up,and check the output-should be AC voltage.
/ Charging Issue
It's the buried under 40 lbs of stuff, type, but if I find the stator is toasted, it will be getting an AC Delco SI 35amp upgrade! Parts are hard to comeby for these Pasquali's, so upgrades are almost a requirement.
I will check the AC output coming out of the stator tonight, should I have AC on all 3 legs coming out of the stator or just 2?
Had my voltmeter & loadmeter on it this morning in the dark, clearing out the heavy-wet, 10" of "white-stuff," while only running 1 back-up light & 2 running lights. Had rpm at 2000, with 12.7v and 2.3amp output, not great but at least not drawing the battery below 12vdc.
Thanks again,
Shadow
/ Charging Issue
Ok, disconnected the 2 yellows & red coming out of the stator. Have 40vac on one yellow & red (common), & nothing on the other yellow to red. I think the stator windings are shot or their is an open circuit somewhere in it.
Shadow
2008 Kawasaki ZX1000 Motorcycle, VIN # JKAZXCE1X8A013733 (A65563)
2008 Kawasaki...
2022 EZ-GO ELITE...
Heavy Duty Fork Extensions (A65640)
Heavy Duty Fork...
2006 Dodge Ram 1500 Pickup Truck (A61568)
2006 Dodge Ram...
2022 BOBCAT T76 SKID STEER (A65053)
2022 BOBCAT T76...
2025 Fabrique 12' x 6' Dump Trailer (A62613)
2025 Fabrique 12'...
