Charging issue today YM2310 then fixed it
   / Charging issue today YM2310 then fixed it #1
etpm
Veteran Member
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
I thought my battery had bad connections. There was lots of corrosion and the battery clamps were junk. So I bought some nice brass ones, cleaned up the corrosion, charged the battery and everything worked great. But then the problem returned, the battery seemed to be bad. But after putting the thing on the charger the green doodad in the window would show a good charge and the tractor would start right up and do so for a couple weeks. Then this morning it dawned on me, the battery wasn't getting charged. So I checked the voltage at the battery while the engine was running and sure enough, it wasn't getting charged. So I pulled apart the connector from the tiny alternator to check the voltage it was putting out. When checking the voltage I accidentally, but quite briefly, shorted the output from the alternator with one of the meter leads. This made a small spark. Then I checked the voltage and it was 20 volts. The connector looked like there was some white corrosion on the spade connectors. Not much, but it was there. I'm out of contact cleaner so I ordered some so that I can clean the connector. Anyway, there is now 14.70 volts at the battery. Before I fiddled with the connector and shorted the alternator the voltage at the battery terminals didn't change from the 13.6 volts measured after I charged the battery and started the tractor a couple times, so I knew the battery wasn't getting charged. I'm wondering now if the brief short woke up the alternator and that's why it's now charging or if cleaning the spade connector by pulling it apart and re-connecting a few times did the job. I think it was the short. I showed that alternator I meant business and was gonna replace it if wasn't gonna perform up to snuff. Or maybe cleaning the connector actually did the trick. You be the judge.
Cheers,
Eric
(INOP) CATERPILLAR 416B BACKHOE (A50459)
(INOP) CATERPILLAR...
Chevrolet C8500 Flat Bed with a Moffet Kit (A51039)
Chevrolet C8500...
EVERYTHING SOLD AS-IS WHERE IS!! (A50774)
EVERYTHING SOLD...
(INOPERABLE) MAROOKA (A50854)
(INOPERABLE)...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2004 KENWORTH BUCKET TRUCK(INOPERABLE) (A50854)
2004 KENWORTH...
