"Charging Button on 12v conversion"
   / "Charging Button on 12v conversion" #1
MarlinSlayer
Bronze Member
Collierville, TN
Ford Jubilee!
Well I bought my Jubilee from a guy who didn't know much about them. It's got a little button (Relay I suspect) that you have to press in order to get the altenator to actually charge. When you press the button after start, sure enough the ammeter jumps up.
If you don't remember, I burned up a starter that was already smoking trying to get the tractor to start after replacing points, condenser, wires, cap and plugs. Finally got the oled Jube home and removed starter and had it completely reworked. Only got it to crank once.... and when I hit starter again, I heard solenoid click and nothing else. Voltages all seem wrong, and I compared the wiring briefly to the 12v wiring diagrams and noticed none had a charging button. I've seen a restored one with what looked like a button in the middle of the cluster...but it could have been a light. I've searched the web and parts store and can't find a reference to afore said button.
This is the restored tractor...is that a light or a charging button
Is the charging button standard, or is it some kind of aftermarket genius of some guy who thought he had a good idea.
As far as the starter is concerned. When it doesn't crank, I hear an initial click of the solenoid, then nothing...then on repeated attempts, do not hear the solenoid click. Lights will not work at that point. disconnected battery, waited a while, then reconnected the battery and I could get the solenoid to click and then nothing. This happened the first timeI tried to crank tractor. took out starter hit it with jumpers, it spun, so I re-installed it, tightened ground, then cranked it once with plugs out. next time I cranked it, solenoid clicked, then nothing...on additional attempts, solenoid would not click and lights would not work. I suspect there might be something wrong with starter solenoid and am thinking about doing a complete rewire as the existing connections look pretty poor. This is when I found that my charging button didn't appear on any parts list.
Any help? I checked the Battery of unknown age and it is strong. Is this a grounding problem, or do solenoids go bad and short out a little?
What about this mystery charging button?
On a side note, I looked at serial number today and I think that this was the last Jube made in '53...next number is a 54 model....does that make it any more valuable? I'm going to check compression if I can ever get it to crank consistently. rumoured to be rebuilt about 4 years ago, and except for a bad dogleg and a rough grill, some other cosmetics it ran strong until it wouldn't start. Proof meter says 450
also, are there quick tests to see if a starting solenoid is good...they are cheap I think so I don't mind just replacing it. I am handy with a voltmeter....how about tests on the voltage regulator?
   / "Charging Button on 12v conversion" #3
The charging button is just there to turn the alternator on so that it charges. If you replace the button with a light it will do the same thing only you won't have to push the button to make the alternator charge.
The symptoms you describe, to me indicates a really poor battery connection somewhere.
   / "Charging Button on 12v conversion" #4
charge button.. had to giggle a bit. ;)
Someone was a bit too lazy to put a 194 lamp or a diode in line from the switched side of the key to the #1 terminal on the alt. #2 terminal on the alt should loop to the charge stud ( assuming this is a gm 10/12 SI alt ).
If you use a diode, get one at least capable of 1a, 50PIV, though 3a / 200 piv is preferred. the diode has a stripe.. strip goes toward the alternator.
The diode method will be automagic. the lamp method will work as follows: key on= lamp on, after starting and getting over 400 rpms or so, lamp flickers out as alternator starts charging.
to test a 4 terminal iso base solenoid, remove it from the tractor and wireing, then simply hook power to one small terminal, ground to one small terminal, and see if she clicks. if yes, hook bat to one large terminal, and a load to the other large terminal, ( a lamp will do ). if it passes this, reinstall on tractor and test.
Ok, I checked all my grounds, got the battery all good and tight and starter starts. While looking around under hood, wiring is very ugly. Oil pressure guage is very rusty and pressure line looks questionable. I also have gas on the underside of the tank and it is always "out of gas" the wet spot is near the front mounting area by what looks like some felt. There appears to be a spring mounted mounting bolt up there. Please tell me there is an orifice up there that is there on purpose that just needs a new plug....otherwise time for a new tank. If I'm going to do that then off comes the tins and also a new wire job. And to think this started with new plugs and wires. I've got some more questions I'll put in another thread. Thanks Soundguy....I think you'll be my new best friend.
P.S. When I uninstalled the "charging button", you should have seen the West Memphis engineering job on this thing....many washers and "engineered" plastic to take up the slack so the bezel threads could engage. It's gonna get a light. I imagine the 12v dash lamp at Steiner is ok?
   / "Charging Button on 12v conversion" #7
For an alt lamp, get something with a 194 bulb, like a trailer marker lamp. I dont know what the Steiner lamp is, but off too high wattage it wont isolate the ignition, plus you can't use it for a dash lamp if it I setup as an iso lamp.
Sounds like front seam of the rank, not uncommon.. You might lune the tank, but replacement will be less hassle.
Couldn't find a diode so I tried an LED idiot light oriented the right way. I don't think it'll do the trick because the light never goes out. Alternator output only 12.5 so I think I'm reading Bat voltage.
The radio shack around here closed. I gotta find another source for the diode.
2016 Komatsu PC210 LC-11 Excavator (A53117)
2016 Komatsu PC210...
1-Pallet Truck Equipment (A53117)
1-Pallet Truck...
2016 Chevrolet Tahoe SUV (A52377)
2016 Chevrolet...
Как зайти с телефона на кракен. kra39ac.cc  | Kraken зайти на площадку? как пополнить кошелёк? Правила диспута
Как зайти с...
2000 POLARIS MAGNUM 325 ATV (A51406)
2000 POLARIS...
AIRMAN PDS 100S COMPRESSOR (A53843)
AIRMAN PDS 100S...
