Changing Transmission oil on JD2520
   / Changing Transmission oil on JD2520 #1
Rand
My JD 2520 is about due for the 50 hr. service, which includes changing the transmission oil. I never did this before and was curious about how much transmission oil I should expect to pour out of once the plug is removed? The
owner's manual lists the transmission as holding a total of 3.9 gallons. Can't imagine having all that fluid pour out once the transmission drain plug is removed. Appreciate any advice or information regarding this.
   / Changing Transmission oil on JD2520 #2
After First 50 Hours
Change engine oil and filter.
Change transmission oil and filter.
Clean transmission suction screen.
OMLVU19796_F9
   / Changing Transmission oil on JD2520 #3
You'll probably get alittle over 3 gal out of it.
I use one of these, it'll hold 5 gal.
   / Changing Transmission oil on JD2520 #4
Fluid Capacities
Fuel Tank 27 L (7.1 gal)
Cooling System 3.9 L (4.1 qt)
Crankcase with Filter 2.8 L (3.0 qt)
Transmission and Hydraulic System 14.6 L (3.9 gal)
Front Axle 3.4 L (3.6 qt)
   / Changing Transmission oil on JD2520 #6
Rand,
Don't forget to drain the reduction boxes at the ends of the rear axle.
Also the crankcase with filter is 4 quarts and not the three the manual states.
   / Changing Transmission oil on JD2520 #7
Also, remember that there are three plugs to be removed. The final drives each have a drain.
I have a large oil change dolly from Northern Tool that fits just right under the transaxle and is great for catching the mess when you remove the filter. I use a flat metal plate leaning against the inside of the rear wheel to direct the flow of oil from the final drive drains into the dolly. It's really pretty easy to do the fluid changes on this tractor. You should have no problem as long as you have a large enough drain pan.
   / Changing Transmission oil on JD2520 #8
Silly question, but do you drain the transmission oil from all three locations at once or close one up and then move to the next?
Secondly will very much oil drain from the final drives?
Willl is that a JD drain pan? Looks like I am going to need a bigger boat er I mean drain pan.
New Wolverine Skidloader Sickle Bar Mower (A50774)
New Wolverine...
Year: 2013 Make: Chevrolet Model: Caprice Vehicle Type: Passenger Car Mileage: 73,798 Plate: Body (A50324)
Year: 2013 Make...
2016 Takeuchi TL8 (A47384)
2016 Takeuchi TL8...
2007 KUBOTA M5040F TRACTOR WITH LOADER (A51243)
2007 KUBOTA M5040F...
Power River Livestock Loading Shute (A50515)
Power River...
2005 KUBOTA L39 BACKHOE (A51242)
2005 KUBOTA L39...
