Changing transmission oil on Gravely Pro-Turn 260
   / Changing transmission oil on Gravely Pro-Turn 260 #1
drssg
Veteran Member
Ohio
Kubota M5700, BX2350
I bought this mower last year, and I just did the initial break-in service for the transmission oil and filters. I got it done, but good gravy, what a hassle! I'm thinking there HAS to be an easier way.
When adding the new fluid, the manual says to remove an upper breather plug, and fill until the fluid starts coming out. Then I put the plug back in and fill to the required level in the reservoir. The breather plug is practically impossible to see and touch, much less get a wrench on it. I managed to get a 1/4" socket wrench in place, but the process was quite tedious. I have to think that professional mechanics find an easier way.
Anyone have experience on these mowers?
   / Changing transmission oil on Gravely Pro-Turn 260 #2
My Grasshopper front mount is due for a filter and hydro oil change, but my seat platform hinges up exposing the whole transmission and wheel motors. I've seen some of the procedures for other mowers that require wheel removal and clear extension hoses attached to funnels so you can watch the oil slowly trickle in until it overflows. I didn't realize how good I have it until seeing some of those videos for other mowers.
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
2005 V.E. ENTERISES 130 BBL STEEL VACUUM TRAILER (A53843)
2005 V.E...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
2020 CAT Skid Steer (A52377)
2020 CAT Skid...
Toro Multi Pro 5800 (A53424)
Toro Multi Pro...
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
