Changing Transmission Fluid on 4500 PowrReverser
   / Changing Transmission Fluid on 4500 PowrReverser #1
MMH
Murrysville, PA
JD 4500
I need to change the transmission fluid on my 4500 PowrReverser. I read thru the manual, but are there any other tips that anyone can give me?
   / Changing Transmission Fluid on 4500 PowrReverser #2
I have no idea how much tranny fluid is in a 4500 PR; but my 4200 HST holds close to 7-gallons, and all I can suggest is have a large container handy to catch the oil. I know, I know...I state the obvious; but changing tranny oil on mine always ends up to be the messiest, most miserable chore of the 200-hour service.
Have fun(?), wear disposable gloves, and keep plenty of rags and oil-dry handy.
   / Changing Transmission Fluid on 4500 PowrReverser #3
I have done mine as I own a 4500 as well. Like mjn said, have large containers available. It seems easier to handle a couple containers that aren't all the way full and less chance for spillage. Be sure to change the filter and take the filter screen out and clean/check for debris. It can be a little bit of a pain to refill it when done. Just take your time to avoid any messes! Good luck! Mike
   / Changing Transmission Fluid on 4500 PowrReverser #4
They're ALL a messy chore - doesn't matter make or model!! Have changed the tranny fluid on 4 different tractors around the place and have oily (still) shirt sleeves to prove it! :laughing: My advice is do not -- do not attempt that job on a gravel driveway...
AKfish
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
CUTTING TORCH (A53843)
2015 FORD F250 EXT CAB SUPER DUTY (A53843)
2015 FORD F250 EXT...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
2025 Auger Mini Skid Steer Attachment (A53421)
2025 Auger Mini...
2016 John Deere 755K Crawler Loader (A47477)
2016 John Deere...
