gordon21
Veteran Member
I called several local shops to verify the price on a transmission fluid change. Apparently things have changed a lot in the past several years. No one wants to drop the pan and change the fluid the old fashioned way. All they want to do is suction out the fluid and replace it. 14 old qts out and 14 new back in. Never touch a wrench.
Isn't there a filter or screen that needs to be cleaned in a 2006 F-150 tranny??? I find it hard to believe that all the crud and metal shavings is going to be vacuumed out. There is 2 years worth in there from when the truck was new.
The only place that will drop the pan is the Ford dealer and that costs $15 more than the regular service. Oddly enough, they tell me that if they drop the pan, they only replace 6 qts. The vacuum method replaces 14 qts
What is going on here????
14qt suction method has been quoted $125-162
